HI all'
I tried to load up my maya 2016 this morning and came across a wierd error I have never seen before?? I really need help and wish not to have to uninstall any of my maya's plug-ins as I also have the 2014 edition, I have a few plug-in's in the 2016 verstion that I feel will be tedious to re-Instal.. anyway im going to now post the error for all to see, fingers crossed someone can help me.
I get a Command window appear with the following errors:
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/startup/layerEditor.mel line 4364: Could not find attribute named "defaultRenderLayer.precompTemplate" //
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/muscle/cMuscle.mel line 519: menu: Object 'mainRigDeformationsMenu' not found. //
// BifrostMain plug-in loaded (built Aug 24 2015 23:02:39)
// fracture: switching to legacy/default viewport
// AbcExport v1.0 using Alembic 1.5.4 (built May 9 2014 15:43:11)
// AbcImport v1.0 using Alembic 1.5.4 (built May 9 2014 15:43:11)
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/others/addSelectTypeItem.mel line 115: Cannot find procedure "updateSelectTypeItemState". //
// Error: line 1: initializePlugin function failed (gpuCache) //
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/others/addNewShelfTab.mel line 71: setParent: Object '' not found. //
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem". //
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/others/addMenuItemSafe.mel line 63: menu: Object 'mainCreateMenu' not found. //
// Error: file: /Applications/Autodesk/maya2016/plug-ins/xgen/scripts/muAddShelfButton.mel line 114: Object '' not found. //
updateRendererUI;
(1ST WINDOW)
(2ND WINDOW)
This is the second window its called a Stack Trace window that also appears with the first one.
This is what it says.
Start of trace: (command window: line 1).
MTsetToggleMenuItem (command window: line 1).
.....Help....me... :'(
Thank you
UnbornFamas
