My group has several animators using either Maya 2012 or Maya 2013. Last week, our maya license starting crashing
once or twice a day. When it crashes we get odd messages like the one below the ***************.
I am not sure why it is crashing. I am going to try to set the variable name to FLEXLM_TIMEOUT to
1000000 to keep the license from crashing. If anybody has any insights for why the license manager
has suddenly freaked out or what else we can do to prevent, I would appreciate any insights.
Lori
slim Feb 25 17:27:50 INFO /svs/share/pixar/config/ini/2013_01_03/_svsRMS_Templates.ini Loaded
slim Feb 25 17:27:50 INFO /svs/share/pixar/config/ini/2013_01_03/_svsLegacyTemplates.ini Loaded
slim Feb 25 17:27:50 INFO /svs/share/pixar/config/ini/2013_01_03/_svsRMS_Layout.ini Loaded
slim Feb 25 17:27:50 INFO /svs/share/pixar/config/ini/2013_01_03/slim.ini Loaded
2013-02-27 08:39:19.396 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x186ef2560 of class NSConcreteMapTable autoreleased with no pool in place - just leaking
2013-02-27 08:39:19.397 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x153715960 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:19.397 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x155672ef0 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:19.400 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x1494c84f0 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:19.400 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x1537a9c40 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:19.469 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x152bcc300 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:19.470 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x152e03e10 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:19.470 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x152e081d0 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:19.470 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x152ecfe90 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:20.185 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x152bd2e10 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:20.185 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x152edd230 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:20.186 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x13a306540 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:20.186 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x13a337460 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
QObject::setParent: Cannot set parent, new parent is in a different thread
QObject::startTimer: QTimer can only be used with threads started with QThread
2013-02-27 08:39:20.220 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x13a3f3550 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:20.220 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x152b89cf0 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:20.221 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x13a3f9af0 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:20.221 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x13a370910 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:21.931 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x1856326c0 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:21.932 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x13a081050 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:21.933 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x12f23ff00 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
2013-02-27 08:39:21.933 Maya[96268:2b17] *** __NSAutoreleaseNoPool(): Object 0x152c74b40 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
WARNING: The connection to the license server was lost. Your work has been saved to the file named: /svs/projects/aquarius/salinity_and_oscar/maya_greg/scenes/lostlock.96268.ma
