I'm having an issue with Maya suddenly after it working just fine since 2013 was released. I get this error message:
I just updated my GeForce cards drivers, could that have something to do with it? Is there an update I can use for Maya?
I saw another post (and posted on it) that I was having the same issue, but that poster was a little suspect in his message and there was no resolution.
Solved by TravisNave. Go to Solution.
Try this thread:
http://forums.autodesk.com/t5/Installation-Licensing/Maya-2011-Trial-Installation-Error/td-p/2675334
Also, you might try a System Restore back to a day when Maya did work.
