Installation & Licensing
Message 1 of 8
aaronw3d
18385 Views, 7 Replies
MAYA_ALT_EN is not set
For no reason when I opened Maya 2012 an error message appeared stating 'Tried Maya 2012... MAYA_ALT_EN is not set.'
I thought if I upgrade to Maya 2013 using the download from my subscription it would resolve the issue. The only effect was the message stating 'Maya 2013' instead. So help anyone? Can't even open Maya for help.
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: aaronw3d
Message 3 of 8
aaronw3d
in reply to: TravisNave
Thanks for the information. I spent all day trying find a solution, most of the information and links were in regard to student/trila/network versions of Maya, not commercial standalone. FLEXlm does seem to be the issue, there is no such file on my computer's C drive. Next week I'll have a look at the FLEXnet option. But still any reason why Maya would be working fine one day then not the next when I did nothing different?
Message 4 of 8
TravisNave
Something had to have changed.  You might do a system restore back to when it did work, maybe?
Autodesk Forums:
Message 5 of 8
_Dark_Wolf_
The problem is that "FLEXnet Licensing Service 64" isn't running. This is because you maybe have a program for optimize computer start and some services are disabled. So you have to run "msconfig" and check this service or you can run it searching in Start menu.
Message 6 of 8
michellehackett
I recently closed a case where one of our subscription customers was getting this error when attempting to launch Maya 2013. The issue was with the combined network license file not containing the proper package increments to license the previous version. I reccomend you run the license file through the parser first to make sure everything is complete within the license file.
http://licenseparser.com/index.html
Message 7 of 8
wally180
in reply to: _Dark_Wolf_
Thank you very much. I have been trying to get MAYA working all night and this is exactly what the problem was.
Message 8 of 8
Good morning.
After Much struglling and battling with resolving this issue, i finally figured it out.
Thanks to all the tips above, they help expanded my knowledge.
Anyway lets go straigth to the point in steps
Step 1
Open your maya installation folder (C:/Program Files/Autodesk/Maya 2015/Bin)
Step 2
Locate the License file
Step 3
open it with a word editor (Wordpad or Notepad)
- Right Click on it and click open with. In the Dialog box that shows up, select notepad or wordpad and click OK
Step 4:
Edit the first line to this:
MAYA_LICENSE=657F1
- Save and exit.
Step 5:
Go to the Maya Folder in My Documents (C:/Users/User1/Documents/Maya)
Step 6
Delete the Folders there
Step 7:
Reinstall maya and choose the repair mode
Step 8
Run Maya
Step 9:
Activate your Product online or Offline
Step 10:
Congratulations. Welcome to Maya
Administrator Productivity
