Installation & Licensing
Maya 2015 Student Version Installation Problems
5 REPLIES 5
704 Views, 5 Replies
I've been trying to download and install Maya Student Version 2014 for a while. I have been consistently having issues. The browser download corrupts the file. The install now slows my downloading to 1 b/s and says its going to take 3882 days to finish. I actually get somewhere with download now but it ends up stopping.
I'm not sure what to do to fix it. I've also attached the install log which is all greek to me. Any help would be much appreciated.
5 REPLIES 5
camilo.lemos
Hi @Anonymous , welcome to the Autodesk Community!
It looks like your firewall or anti-virus programs are blocking parts of the download.
Please, disable your anti-virus and firewall and restart the download. It should work normally.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Camilo Lemos
in reply to: camilo.lemos
Well I have avast on my computer. I disabled it and it still is showing the same error.
From the installation Log
2014/9/1:19:38:45 Charity  === Setup started on by Charity ===
2014/9/1:19:38:45 Charity  Path_Length: 143
2014/9/1:19:38:45 Charity  Current Directory C:\Users\Charity\AppData\Local\Temp\_AIA297.tmp
2014/9/1:19:38:45 Charity  Launch
2014/9/1:19:38:49 Charity  PageOpen LaunchDialog
2014/9/1:19:39:02 Charity  PageOpen LicenseDialog
2014/9/1:19:39:17 Charity  PageOpen ProductInfoDialog
2014/9/1:19:39:35 Charity  PageOpen ProductSelectionDialog2
2014/9/1:19:39:37 Charity  PageOpen FullProgressDialog
2014/9/1:19:39:37 Charity  Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/1:19:39:38 Charity  Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/1:19:39:38 Charity  Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/1:19:39:39 Charity  Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/1:19:39:39 Charity  Installing DirectX® Runtime: "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/9/1:19:39:42 Charity  Install DirectX® Runtime Succeeded
2014/9/1:19:39:46 Charity  Installing Autodesk® Maya® 2015: TRANSFORMS="C:\Users\Charity\AppData\Local\Temp\_AIA297.tmp\x64\Maya\Maya-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2015_R1_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Maya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/1:19:56:10 Charity  Install Autodesk® Maya® 2015 Failed Installation aborted, Result=1603
2014/9/1:19:56:10 Charity  Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/1:19:56:10 Charity  Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/1:19:56:11 Charity  Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Still having the same exact issue. Is there anything I can do?
ukdxb012
I always download via browser download. This probably won't make much difference but have you tried downloading via IE and Google Chrome? Sometimes I get a lot of issues with IE. When you say it is corrupting the file, what do you mean? Is the exe not usable once download?
I prefer to have the full download on my machine rather than relying on internet connection to download whilst installing.
Have you tried to download on a different connection? Are you constantly using the same machine with same network or have you tried elsewhere like work, college, home. Does that make a difference?
FYI, I have never ever disabled my antivirus when installing/downloading Autodesk products, this has never caused me any issues.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
ukdxb012
in reply to: ukdxb012
If you are using the machine that is downloading, my recommendation would be to only download. Close everything down except the web browser and repeat the download process. Turn of any competing or conflicting program's like antivirus, virus scanners, word, excel and system utilities.
Some further 1603 error tips can be found here... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1...
Duncan Brannan
Twitter | LinkedIn
Administrator Productivity
