Installation & Licensing
Maya 2015 Student install fail - result = 1619 & 1603
6 REPLIES 6
Geo_Fri
3164 Views, 6 Replies
Hello, I have been trying to download the student version of Maya 2015 recently. I already installed AutoCAD 2015 and installed then uninstalled 3DS Max as I thought Maya would be a better fit for me. My first two installations went perfectly, but I have been having many problems with installing Maya. I have perused through the forums, uninstalled all Microsoft C++ Visual programs it errors with, but to no avail. Here is the complete failed installation log:
2014/9/15:07:25:19	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:07:25:19	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:07:25:19	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/15:07:25:19	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:07:25:19	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/15:07:25:19	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI841D.tmp
2014/9/15:07:25:23	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:07:25:20	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:07:25:20	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:07:25:20	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI841D.tmp
2014/9/15:07:25:20	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:07:25:21	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/15:07:25:21	Geo_Fri	GEO-GAMING-PC	Connection has expired. Please reconnect to site.2014/9/15:07:25:24	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:07:25:45	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:07:25:45	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:07:25:45	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/15:07:25:45	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:07:25:45	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/15:07:25:45	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIEB44.tmp
2014/9/15:07:25:49	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:07:25:46	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:07:25:46	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:07:25:46	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIEB44.tmp
2014/9/15:07:25:46	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:07:25:47	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/15:07:25:48	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/15:07:25:53	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/15:07:25:53	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/15:07:25:53	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/15:07:25:55	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/15:07:25:55	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	VCREDIST2010SP1X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/15:07:25:55	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2010 SP1 Redistributable (x86)	Failed	Download Failed, Installation aborted, Result=1603
2014/9/15:07:25:56	Geo_Fri	GEO-GAMING-PC	PageOpen	InstallCompleteDialog
2014/9/15:07:25:59	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:07:32:18	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:07:32:18	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:07:32:18	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/15:07:32:18	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:07:32:18	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/15:07:32:18	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI5990.tmp
2014/9/15:07:32:20	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:07:32:19	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/15:07:32:20	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/15:07:32:27	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/15:07:32:27	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/15:07:32:27	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/15:07:32:29	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/15:07:32:30	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	VCREDIST2010SP1X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/15:07:32:30	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2010 SP1 Redistributable (x86)	Failed	Download Failed, Installation aborted, Result=1603
2014/9/15:07:32:30	Geo_Fri	GEO-GAMING-PC	PageOpen	InstallCompleteDialog
2014/9/15:07:32:32	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:07:39:35	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:07:39:35	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:07:39:35	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/15:07:39:35	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:07:39:35	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/15:07:39:35	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI67C.tmp
2014/9/15:07:39:39	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:07:39:36	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:07:39:36	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:07:39:36	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI67C.tmp
2014/9/15:07:39:36	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:07:39:36	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/15:07:39:37	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/15:07:39:46	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/15:07:39:46	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/15:07:39:46	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/15:07:39:49	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/15:07:39:50	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	VCREDIST2010SP1X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/15:07:39:50	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2010 SP1 Redistributable (x86)	Failed	Download Failed, Installation aborted, Result=1603
2014/9/15:07:45:47	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:07:45:47	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:07:45:47	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/15:07:45:47	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:07:45:47	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/15:07:45:47	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIAA8E.tmp
2014/9/15:07:45:50	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:07:45:48	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/15:07:45:51	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/15:07:45:56	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/15:07:45:56	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/15:07:45:56	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/15:07:45:58	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/15:07:46:00	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	VCREDIST2010SP1X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/15:07:46:00	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2010 SP1 Redistributable (x86)	Failed	Download Failed, Installation aborted, Result=1603
2014/9/15:07:46:00	Geo_Fri	GEO-GAMING-PC	PageOpen	InstallCompleteDialog
2014/9/15:07:56:43	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:08:03:01	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:08:03:01	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:08:03:01	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/15:08:03:01	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:08:03:01	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/15:08:03:01	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI744D.tmp
2014/9/15:08:03:07	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:08:03:02	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:08:03:02	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:08:03:02	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI744D.tmp
2014/9/15:08:03:02	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:08:03:04	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/15:08:03:04	Geo_Fri	GEO-GAMING-PC	Connection has expired. Please reconnect to site.2014/9/15:08:03:07	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:08:03:27	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:08:03:27	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:08:03:27	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/15:08:03:27	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:08:03:27	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/15:08:03:27	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AID828.tmp
2014/9/15:08:03:31	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:08:03:28	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:08:03:28	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:08:03:28	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AID828.tmp
2014/9/15:08:03:28	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:08:03:30	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/15:08:03:30	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/15:08:03:37	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/15:08:03:37	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/15:08:03:37	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/15:08:03:40	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/15:08:03:41	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	VCREDIST2012X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/15:08:03:41	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Download Failed, Installation aborted, Result=1603
2014/9/15:08:03:41	Geo_Fri	GEO-GAMING-PC	PageOpen	InstallCompleteDialog
2014/9/15:08:14:21	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:08:14:51	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/15:08:14:51	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/15:08:14:51	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/15:08:14:51	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/15:08:14:51	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/15:08:14:51	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI46CF.tmp
2014/9/15:08:14:55	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/15:08:14:54	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/15:08:14:55	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/15:08:15:00	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/15:08:15:00	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/15:08:15:00	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/15:08:15:03	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/15:08:15:03	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	VCREDIST2012X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/15:08:15:03	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Download Failed, Installation aborted, Result=1603
2014/9/17:17:20:30	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/17:17:20:30	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:20:30	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/17:17:20:30	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/17:17:20:30	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/17:17:20:30	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI9102.tmp
2014/9/17:17:20:38	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/17:17:20:31	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/17:17:20:31	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:20:31	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI9102.tmp
2014/9/17:17:20:31	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/17:17:20:34	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/17:17:20:39	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/17:17:20:50	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/17:17:20:50	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/17:17:20:50	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/17:17:21:14	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/17:17:21:14	Geo_Fri	GEO-GAMING-PC	Download	Play	VCREDIST2012X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:21:36	Geo_Fri	GEO-GAMING-PC	Download	Complete	VCREDIST2012X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:21:36	Geo_Fri	GEO-GAMING-PC	Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/17:17:22:06	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Succeeded
2014/9/17:17:22:07	Geo_Fri	GEO-GAMING-PC	Download	Play	VCREDIST2012X64	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:22:30	Geo_Fri	GEO-GAMING-PC	Download	Complete	VCREDIST2012X64	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:22:30	Geo_Fri	GEO-GAMING-PC	Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/17:17:22:30	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x64)	Succeeded
2014/9/17:17:22:31	Geo_Fri	GEO-GAMING-PC	Download	Play	DIRECTX	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/9/17:17:22:53	Geo_Fri	GEO-GAMING-PC	Download	Complete	DIRECTX	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/9/17:17:22:53	Geo_Fri	GEO-GAMING-PC	Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/17:17:23:00	Geo_Fri	GEO-GAMING-PC	Install	DirectX® Runtime	Succeeded
2014/9/17:17:23:01	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	MAYA	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/17:17:23:01	Geo_Fri	GEO-GAMING-PC	Install	Autodesk® Maya® 2015	Failed	Download Failed, Installation aborted, Result=1603
2014/9/17:17:23:01	Geo_Fri	GEO-GAMING-PC	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2014/9/17:17:23:01	Geo_Fri	GEO-GAMING-PC	Rollback	Microsoft Visual C++ 2012 Redistributable (x64)	Failed	Installation aborted, Result=1619
2014/9/17:17:23:01	Geo_Fri	GEO-GAMING-PC	Rollback	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Installation aborted, Result=1619
2014/9/17:17:23:01	Geo_Fri	GEO-GAMING-PC	PageOpen	InstallCompleteDialog
2014/9/17:17:26:43	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/17:17:26:37	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/17:17:26:37	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:26:37	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/17:17:26:37	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/17:17:26:37	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/17:17:26:37	Geo_Fri	GEO-GAMING-PC	Another Autodesk install/update is now occurring on this computer.  Please wait for that to complete and then click Retry.2014/9/17:17:26:46	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:26:46	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI2A2D.tmp
2014/9/17:17:26:55	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/17:17:26:50	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/17:17:26:50	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:26:50	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI2A2D.tmp
2014/9/17:17:26:50	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/17:17:26:51	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/17:17:26:51	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/17:17:27:00	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/17:17:27:00	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/17:17:27:00	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/17:17:27:03	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/17:17:27:03	Geo_Fri	GEO-GAMING-PC	Download	Skipped	VCREDIST2012X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:27:03	Geo_Fri	GEO-GAMING-PC	Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/17:17:27:05	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Succeeded
2014/9/17:17:27:05	Geo_Fri	GEO-GAMING-PC	Download	Skipped	VCREDIST2012X64	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:27:05	Geo_Fri	GEO-GAMING-PC	Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/17:17:27:05	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x64)	Succeeded
2014/9/17:17:27:05	Geo_Fri	GEO-GAMING-PC	Download	Skipped	DIRECTX	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/9/17:17:27:05	Geo_Fri	GEO-GAMING-PC	Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/17:17:27:10	Geo_Fri	GEO-GAMING-PC	Install	DirectX® Runtime	Succeeded
2014/9/17:17:27:11	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	MAYA	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/17:17:27:11	Geo_Fri	GEO-GAMING-PC	Install	Autodesk® Maya® 2015	Failed	Download Failed, Installation aborted, Result=1603
2014/9/17:17:27:11	Geo_Fri	GEO-GAMING-PC	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2014/9/17:17:27:11	Geo_Fri	GEO-GAMING-PC	Rollback	Microsoft Visual C++ 2012 Redistributable (x64)	Failed	Installation aborted, Result=1619
2014/9/17:17:27:11	Geo_Fri	GEO-GAMING-PC	Rollback	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Installation aborted, Result=1619
2014/9/17:17:27:12	Geo_Fri	GEO-GAMING-PC	PageOpen	InstallCompleteDialog
2014/9/17:17:29:03	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/17:17:29:34	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/17:17:29:34	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:29:34	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/17:17:29:34	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/17:17:29:34	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/17:17:29:34	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIDAE5.tmp
2014/9/17:17:29:38	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/17:17:29:35	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/17:17:29:36	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/17:17:29:41	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/17:17:29:41	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/17:17:29:41	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/17:17:29:43	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/17:17:29:44	Geo_Fri	GEO-GAMING-PC	Download	Skipped	VCREDIST2012X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:29:44	Geo_Fri	GEO-GAMING-PC	Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/17:17:29:44	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Succeeded
2014/9/17:17:29:44	Geo_Fri	GEO-GAMING-PC	Download	Skipped	VCREDIST2012X64	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:29:44	Geo_Fri	GEO-GAMING-PC	Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/17:17:29:47	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x64)	Succeeded
2014/9/17:17:29:47	Geo_Fri	GEO-GAMING-PC	Download	Skipped	DIRECTX	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/9/17:17:29:47	Geo_Fri	GEO-GAMING-PC	Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/17:17:29:53	Geo_Fri	GEO-GAMING-PC	Install	DirectX® Runtime	Succeeded
2014/9/17:17:29:54	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	MAYA	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/17:17:29:54	Geo_Fri	GEO-GAMING-PC	Install	Autodesk® Maya® 2015	Failed	Download Failed, Installation aborted, Result=1603
2014/9/17:17:29:54	Geo_Fri	GEO-GAMING-PC	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2014/9/17:17:29:54	Geo_Fri	GEO-GAMING-PC	Rollback	Microsoft Visual C++ 2012 Redistributable (x64)	Failed	Installation aborted, Result=1619
2014/9/17:17:29:54	Geo_Fri	GEO-GAMING-PC	Rollback	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Installation aborted, Result=1619
2014/9/17:17:29:54	Geo_Fri	GEO-GAMING-PC	PageOpen	InstallCompleteDialog
2014/9/17:17:35:21	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/17:17:36:48	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/17:17:36:48	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:36:48	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/17:17:36:48	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/17:17:36:48	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/17:17:36:48	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI7B9D.tmp
2014/9/17:17:36:52	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/17:17:36:49	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/17:17:36:49	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:36:49	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI7B9D.tmp
2014/9/17:17:36:49	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/17:17:36:50	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/17:17:36:50	Geo_Fri	GEO-GAMING-PC	Connection has expired. Please reconnect to site.2014/9/17:17:36:53	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/17:17:37:07	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/17:17:37:07	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:37:07	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/17:17:37:07	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/17:17:37:07	Geo_Fri	GEO-GAMING-PC	CommandLine	/url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/17:17:37:07	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIC632.tmp
2014/9/17:17:37:10	Geo_Fri	GEO-GAMING-PC	=== Setup ended ===
2014/9/17:17:37:08	Geo_Fri	GEO-GAMING-PC	=== Setup started on GEO-GAMING-PC by Geo_Fri ===
2014/9/17:17:37:08	Geo_Fri	GEO-GAMING-PC	Path_Length: 143
2014/9/17:17:37:08	Geo_Fri	GEO-GAMING-PC	Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIC632.tmp
2014/9/17:17:37:08	Geo_Fri	GEO-GAMING-PC	Launch
2014/9/17:17:37:09	Geo_Fri	GEO-GAMING-PC	Download	Skipped	SETUP_CONFIG	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/17:17:37:09	Geo_Fri	GEO-GAMING-PC	PageOpen	LaunchDialog
2014/9/17:17:37:18	Geo_Fri	GEO-GAMING-PC	PageOpen	LicenseDialog
2014/9/17:17:37:18	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductInfoDialog
2014/9/17:17:37:18	Geo_Fri	GEO-GAMING-PC	PageOpen	ProductSelectionDialog2
2014/9/17:17:37:42	Geo_Fri	GEO-GAMING-PC	PageOpen	FullProgressDialog
2014/9/17:17:37:42	Geo_Fri	GEO-GAMING-PC	Download	Skipped	VCREDIST2012X86	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:37:42	Geo_Fri	GEO-GAMING-PC	Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/17:17:37:42	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Succeeded
2014/9/17:17:37:42	Geo_Fri	GEO-GAMING-PC	Download	Skipped	VCREDIST2012X64	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/9/17:17:37:42	Geo_Fri	GEO-GAMING-PC	Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/17:17:37:43	Geo_Fri	GEO-GAMING-PC	Install	Microsoft Visual C++ 2012 Redistributable (x64)	Succeeded
2014/9/17:17:37:43	Geo_Fri	GEO-GAMING-PC	Download	Skipped	DIRECTX	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/9/17:17:37:43	Geo_Fri	GEO-GAMING-PC	Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/17:17:37:48	Geo_Fri	GEO-GAMING-PC	Install	DirectX® Runtime	Succeeded
2014/9/17:17:37:49	Geo_Fri	GEO-GAMING-PC	Download Error	Connection has expired. Please reconnect to site.	MAYA	http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/17:17:37:49	Geo_Fri	GEO-GAMING-PC	Install	Autodesk® Maya® 2015	Failed	Download Failed, Installation aborted, Result=1603
2014/9/17:17:37:49	Geo_Fri	GEO-GAMING-PC	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2014/9/17:17:37:49	Geo_Fri	GEO-GAMING-PC	Rollback	Microsoft Visual C++ 2012 Redistributable (x64)	Failed	Installation aborted, Result=1619
2014/9/17:17:37:49	Geo_Fri	GEO-GAMING-PC	Rollback	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Installation aborted, Result=1619
 I would appreciate any help.
6 REPLIES 6
TravisNave
in reply to: Geo_Fri
Log file explained here:
http://forums.autodesk.com/t5/installation-licensing/how-to-determine-errors-in-installation-log-fil...
 I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
Geo_Fri
in reply to: TravisNave
Thanks! I finally got it to work by restarting a few times and using one of the other install options - thanks for the thorough reply!
I downloaded 64 bit Maya  from the virtual assistant. restartd my computer and ran setup. fails exctly in the same place with the 1619 error.
please advise.
thanks
Hi!
Please can you tell me which of the "other install options" worked for you. I downloade from the irtual assistant and tried installing with no success.
thanks
sriram
Geo_Fri
I'm not exactly sure which one worked for me, but it was the one where you download the entire program instead of just the installer. I am not at my computer now so I can't tell you exactly, but if you can't get it by tonight I can.
Sent from my iPhone
I'm having the same issue. Has anyone figured out an exact way to fix this?
I'm on my 3rd computer ( goingback and forth to best buy)
thinking it was a computer issue.
-M
Administrator Productivity
