Hello, I have been trying to download the student version of Maya 2015 recently. I already installed AutoCAD 2015 and installed then uninstalled 3DS Max as I thought Maya would be a better fit for me. My first two installations went perfectly, but I have been having many problems with installing Maya. I have perused through the forums, uninstalled all Microsoft C++ Visual programs it errors with, but to no avail. Here is the complete failed installation log:
2014/9/15:07:25:19 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:25:19 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:25:19 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/15:07:25:19 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:25:19 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/15:07:25:19 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:25:19 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI841D.tmp 2014/9/15:07:25:23 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:07:25:20 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:25:20 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:25:20 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI841D.tmp 2014/9/15:07:25:20 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:25:21 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/15:07:25:21 Geo_Fri GEO-GAMING-PC Connection has expired. Please reconnect to site.2014/9/15:07:25:24 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:07:25:45 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:25:45 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:25:45 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/15:07:25:45 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:25:45 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/15:07:25:45 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:25:45 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIEB44.tmp 2014/9/15:07:25:49 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:07:25:46 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:25:46 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:25:46 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIEB44.tmp 2014/9/15:07:25:46 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:25:47 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/15:07:25:48 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/15:07:25:53 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/15:07:25:53 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/15:07:25:53 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/15:07:25:55 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/15:07:25:55 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/15:07:25:55 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603 2014/9/15:07:25:56 Geo_Fri GEO-GAMING-PC PageOpen InstallCompleteDialog 2014/9/15:07:25:59 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI5990.tmp 2014/9/15:07:32:20 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI5990.tmp 2014/9/15:07:32:18 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:32:19 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/15:07:32:20 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/15:07:32:27 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/15:07:32:27 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/15:07:32:27 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/15:07:32:29 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/15:07:32:30 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/15:07:32:30 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603 2014/9/15:07:32:30 Geo_Fri GEO-GAMING-PC PageOpen InstallCompleteDialog 2014/9/15:07:32:32 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:07:39:35 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:39:35 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:39:35 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/15:07:39:35 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:39:35 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/15:07:39:35 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:39:35 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI67C.tmp 2014/9/15:07:39:39 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:07:39:36 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:39:36 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:39:36 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI67C.tmp 2014/9/15:07:39:36 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:39:36 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/15:07:39:37 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/15:07:39:46 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/15:07:39:46 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/15:07:39:46 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/15:07:39:49 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/15:07:39:50 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/15:07:39:50 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIAA8E.tmp 2014/9/15:07:45:50 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIAA8E.tmp 2014/9/15:07:45:47 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:07:45:48 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/15:07:45:51 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/15:07:45:56 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/15:07:45:56 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/15:07:45:56 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/15:07:45:58 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/15:07:46:00 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/15:07:46:00 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603 2014/9/15:07:46:00 Geo_Fri GEO-GAMING-PC PageOpen InstallCompleteDialog 2014/9/15:07:56:43 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:08:03:01 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:08:03:01 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:08:03:01 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/15:08:03:01 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:08:03:01 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/15:08:03:01 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:08:03:01 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI744D.tmp 2014/9/15:08:03:07 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:08:03:02 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:08:03:02 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:08:03:02 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI744D.tmp 2014/9/15:08:03:02 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:08:03:04 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/15:08:03:04 Geo_Fri GEO-GAMING-PC Connection has expired. Please reconnect to site.2014/9/15:08:03:07 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:08:03:27 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:08:03:27 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:08:03:27 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/15:08:03:27 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:08:03:27 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/15:08:03:27 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:08:03:27 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AID828.tmp 2014/9/15:08:03:31 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:08:03:28 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:08:03:28 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:08:03:28 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AID828.tmp 2014/9/15:08:03:28 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:08:03:30 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/15:08:03:30 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/15:08:03:37 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/15:08:03:37 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/15:08:03:37 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/15:08:03:40 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/15:08:03:41 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/15:08:03:41 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603 2014/9/15:08:03:41 Geo_Fri GEO-GAMING-PC PageOpen InstallCompleteDialog 2014/9/15:08:14:21 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI46CF.tmp 2014/9/15:08:14:55 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI46CF.tmp 2014/9/15:08:14:51 Geo_Fri GEO-GAMING-PC Launch 2014/9/15:08:14:54 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/15:08:14:55 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/15:08:15:00 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/15:08:15:00 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/15:08:15:00 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/15:08:15:03 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/15:08:15:03 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/15:08:15:03 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603 2014/9/17:17:20:30 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:20:30 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:20:30 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/17:17:20:30 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:20:30 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/17:17:20:30 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:20:30 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI9102.tmp 2014/9/17:17:20:38 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/17:17:20:31 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:20:31 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:20:31 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI9102.tmp 2014/9/17:17:20:31 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:20:34 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/17:17:20:39 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/17:17:20:50 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/17:17:20:50 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/17:17:20:50 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/17:17:21:14 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/17:17:21:14 Geo_Fri GEO-GAMING-PC Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:21:36 Geo_Fri GEO-GAMING-PC Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:21:36 Geo_Fri GEO-GAMING-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2014/9/17:17:22:06 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2014/9/17:17:22:07 Geo_Fri GEO-GAMING-PC Download Play VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:22:30 Geo_Fri GEO-GAMING-PC Download Complete VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:22:30 Geo_Fri GEO-GAMING-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2014/9/17:17:22:30 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2014/9/17:17:22:31 Geo_Fri GEO-GAMING-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar... 2014/9/17:17:22:53 Geo_Fri GEO-GAMING-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar... 2014/9/17:17:22:53 Geo_Fri GEO-GAMING-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent 2014/9/17:17:23:00 Geo_Fri GEO-GAMING-PC Install DirectX® Runtime Succeeded 2014/9/17:17:23:01 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/17:17:23:01 Geo_Fri GEO-GAMING-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603 2014/9/17:17:23:01 Geo_Fri GEO-GAMING-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/9/17:17:23:01 Geo_Fri GEO-GAMING-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2014/9/17:17:23:01 Geo_Fri GEO-GAMING-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619 2014/9/17:17:23:01 Geo_Fri GEO-GAMING-PC PageOpen InstallCompleteDialog 2014/9/17:17:26:43 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/17:17:26:37 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:26:37 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:26:37 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/17:17:26:37 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:26:37 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/17:17:26:37 Geo_Fri GEO-GAMING-PC Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/9/17:17:26:46 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:26:46 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI2A2D.tmp 2014/9/17:17:26:55 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/17:17:26:50 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:26:50 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:26:50 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI2A2D.tmp 2014/9/17:17:26:50 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:26:51 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/17:17:26:51 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/17:17:27:00 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/17:17:27:00 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/17:17:27:00 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/17:17:27:03 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/17:17:27:03 Geo_Fri GEO-GAMING-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:27:03 Geo_Fri GEO-GAMING-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2014/9/17:17:27:05 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2014/9/17:17:27:05 Geo_Fri GEO-GAMING-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:27:05 Geo_Fri GEO-GAMING-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2014/9/17:17:27:05 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2014/9/17:17:27:05 Geo_Fri GEO-GAMING-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar... 2014/9/17:17:27:05 Geo_Fri GEO-GAMING-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent 2014/9/17:17:27:10 Geo_Fri GEO-GAMING-PC Install DirectX® Runtime Succeeded 2014/9/17:17:27:11 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/17:17:27:11 Geo_Fri GEO-GAMING-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603 2014/9/17:17:27:11 Geo_Fri GEO-GAMING-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/9/17:17:27:11 Geo_Fri GEO-GAMING-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2014/9/17:17:27:11 Geo_Fri GEO-GAMING-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619 2014/9/17:17:27:12 Geo_Fri GEO-GAMING-PC PageOpen InstallCompleteDialog 2014/9/17:17:29:03 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIDAE5.tmp 2014/9/17:17:29:38 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIDAE5.tmp 2014/9/17:17:29:34 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:29:35 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/17:17:29:36 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/17:17:29:41 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/17:17:29:41 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/17:17:29:41 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/17:17:29:43 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/17:17:29:44 Geo_Fri GEO-GAMING-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:29:44 Geo_Fri GEO-GAMING-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2014/9/17:17:29:44 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2014/9/17:17:29:44 Geo_Fri GEO-GAMING-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:29:44 Geo_Fri GEO-GAMING-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2014/9/17:17:29:47 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2014/9/17:17:29:47 Geo_Fri GEO-GAMING-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar... 2014/9/17:17:29:47 Geo_Fri GEO-GAMING-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent 2014/9/17:17:29:53 Geo_Fri GEO-GAMING-PC Install DirectX® Runtime Succeeded 2014/9/17:17:29:54 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/17:17:29:54 Geo_Fri GEO-GAMING-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603 2014/9/17:17:29:54 Geo_Fri GEO-GAMING-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/9/17:17:29:54 Geo_Fri GEO-GAMING-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2014/9/17:17:29:54 Geo_Fri GEO-GAMING-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619 2014/9/17:17:29:54 Geo_Fri GEO-GAMING-PC PageOpen InstallCompleteDialog 2014/9/17:17:35:21 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/17:17:36:48 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:36:48 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:36:48 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/17:17:36:48 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:36:48 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/17:17:36:48 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:36:48 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI7B9D.tmp 2014/9/17:17:36:52 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/17:17:36:49 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:36:49 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:36:49 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AI7B9D.tmp 2014/9/17:17:36:49 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:36:50 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/17:17:36:50 Geo_Fri GEO-GAMING-PC Connection has expired. Please reconnect to site.2014/9/17:17:36:53 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/17:17:37:07 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:37:07 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:37:07 Geo_Fri GEO-GAMING-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US 2014/9/17:17:37:07 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:37:07 Geo_Fri GEO-GAMING-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50171550 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/17:17:37:07 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:37:07 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIC632.tmp 2014/9/17:17:37:10 Geo_Fri GEO-GAMING-PC === Setup ended === 2014/9/17:17:37:08 Geo_Fri GEO-GAMING-PC === Setup started on GEO-GAMING-PC by Geo_Fri === 2014/9/17:17:37:08 Geo_Fri GEO-GAMING-PC Path_Length: 143 2014/9/17:17:37:08 Geo_Fri GEO-GAMING-PC Current Directory C:\Users\Geo_Fri\AppData\Local\Temp\_AIC632.tmp 2014/9/17:17:37:08 Geo_Fri GEO-GAMING-PC Launch 2014/9/17:17:37:09 Geo_Fri GEO-GAMING-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t... 2014/9/17:17:37:09 Geo_Fri GEO-GAMING-PC PageOpen LaunchDialog 2014/9/17:17:37:18 Geo_Fri GEO-GAMING-PC PageOpen LicenseDialog 2014/9/17:17:37:18 Geo_Fri GEO-GAMING-PC PageOpen ProductInfoDialog 2014/9/17:17:37:18 Geo_Fri GEO-GAMING-PC PageOpen ProductSelectionDialog2 2014/9/17:17:37:42 Geo_Fri GEO-GAMING-PC PageOpen FullProgressDialog 2014/9/17:17:37:42 Geo_Fri GEO-GAMING-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:37:42 Geo_Fri GEO-GAMING-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2014/9/17:17:37:42 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2014/9/17:17:37:42 Geo_Fri GEO-GAMING-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201... 2014/9/17:17:37:42 Geo_Fri GEO-GAMING-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2014/9/17:17:37:43 Geo_Fri GEO-GAMING-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2014/9/17:17:37:43 Geo_Fri GEO-GAMING-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar... 2014/9/17:17:37:43 Geo_Fri GEO-GAMING-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent 2014/9/17:17:37:48 Geo_Fri GEO-GAMING-PC Install DirectX® Runtime Succeeded 2014/9/17:17:37:49 Geo_Fri GEO-GAMING-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/17:17:37:49 Geo_Fri GEO-GAMING-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603 2014/9/17:17:37:49 Geo_Fri GEO-GAMING-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/9/17:17:37:49 Geo_Fri GEO-GAMING-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2014/9/17:17:37:49 Geo_Fri GEO-GAMING-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
I would appreciate any help.
Solved by TravisNave. Go to Solution.
Log file explained here:
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Thanks! I finally got it to work by restarting a few times and using one of the other install options - thanks for the thorough reply!
I downloaded 64 bit Maya from the virtual assistant. restartd my computer and ran setup. fails exctly in the same place with the 1619 error.
please advise.
thanks
Hi!
Please can you tell me which of the "other install options" worked for you. I downloade from the irtual assistant and tried installing with no success.
thanks
sriram
I'm having the same issue. Has anyone figured out an exact way to fix this?
I'm on my 3rd computer ( goingback and forth to best buy)
thinking it was a computer issue.
-M
