I've been trying to install Maya 2015 student edition for hours and have seemingly tried every option. Here is the error message I'm receiving:
2014/9/12:14:09:45 Don DON-PC === Setup started on DON-PC by Don ===
2014/9/12:14:09:45 Don DON-PC Path_Length: 143
2014/9/12:14:09:45 Don DON-PC Current Directory C:\Users\Don\AppData\Local\Temp\_AI1757.tmp
2014/9/12:14:09:45 Don DON-PC Launch
2014/9/12:14:09:46 Don DON-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/12:14:09:46 Don DON-PC PageOpen LaunchDialog
2014/9/12:14:09:53 Don DON-PC PageOpen LicenseDialog
2014/9/12:14:09:53 Don DON-PC PageOpen ProductInfoDialog
2014/9/12:14:09:53 Don DON-PC PageOpen ProductSelectionDialog2
2014/9/12:14:09:59 Don DON-PC PageOpen FullProgressDialog
2014/9/12:14:10:00 Don DON-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/12:14:10:00 Don DON-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
I've tried uninstalling and reinstalling the C++ 2008 redistributable, along with the 2010 redistributables, and I just can't get it to work. Any help would be much appreciated.
Solved by TravisNave. Go to Solution.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
