Installation & Licensing
Maya 2015 Installation Problem License Was Not Obtained Blank White Screen
13 REPLIES 13
Message 1 of 14
15770 Views, 13 Replies
Hi, I was able to install Maya 2015, but when I click the Activate button to enter the serial number to activate the product a blank white window pops open and I can't enter the serial number or do anything. I tried uninstalling and reinstalling several times and somehow was able to download a trial that has one day left on it. I'm working on a fairly new Dell XPS. Also, when I close everything a window opens that says
License was not obtained Tried Maya 2015, error 19
License method:
environment variable MAYA_LICENSE_METHOD=standalone
Product Choice
environment variable MAYA_LICENSE_METHOD=unlimited
License file override:
environment variable MAYA_ALT_EN is not set
13 REPLIES 13
Message 2 of 14
asburyj
Take a look at the soltutions for that problem in the knowledge article linked below
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Registe...
Jeffry Asbury
Message 3 of 14
in reply to: asburyj
Hi, this solution did not work. Should I just remove internet explorer from
my computer if it is causing the security issues?
Message 4 of 14
asburyj
Intenet explorer is required by our software for the activation process so removing the windows component of internet explorer won't help. However it may help to upgrade/downgrade your internet explorer install if it is corrupt that action may repair it. If you continue to have trouble I would suggest a repair of the windows operating system.
Jeffry Asbury
Message 5 of 14
Hi, if I downloaded Maya 2015 using Google Chrome do you think that could
have caused my problems?
Message 6 of 14
asburyj
No it doesn't matter what browser was used for the download.
Jeffry Asbury
Message 7 of 14
Hi, thanks for answering all my questions. When I'm trying the different
solutions should I be uninstalling Maya 2015 and then reinstalling it?
Message 8 of 14
asburyj
The blank activation screen is a problem with internet explorer loading the activation screen shot uninstalling and re-installing maya doesn't do anything. It's strictly an Internet explorer/Java issue.
Jeffry Asbury
Message 9 of 14
Hi, I still can't download Maya and a message shows up in my Output Window
when I close the activation screen that says license problem in GUI mode
launch dialog message. Does that mean this is a licensing issue, or still
IE and Java?
Message 10 of 14
The solution below worked. I can't believe it was that simple.
I finally found a solution that works atleast for me, it turns out some component of McAfee antivirus is what was causing my activation screen to be blank, you can download the McAfee component remover from the link below, ignore everything else contained in the document and download the remover. I hope this will be of use to someone.
http://support.esri.com/cn/knowledgebase/techarticles/detail/41057
Message 11 of 14
raul1968
I just tried editing my rtbeginreg.html document and found it to be 37k of blank.  How do i get a new one?
Message 12 of 14
raul1968
I was reading your trouble and had the same. I tried everything... than you gave me an idea. I uninstalled maya 2015. installed 3ds max trial version so i didn't use my student key ... than reinstalled maya 2015.. it worked for me
Message 13 of 14
Do the following:
1. Press windows button + r to star Run and type 'services.msc'.
2. Click the 'Standard' tab on the bottom.
3. Find 'FLEXnet Licensing.. blaa' and right click for 'Stop'.
4. Right click again for properties and set 'Startup type' to 'Automatic' and press 'Start' below.
5. Apply and you are done!
Hopefully this works. Good luck!
thnx to
http://simplymaya.com/forum/showthread.php?t=36276
Message 14 of 14
tambem estou tendo problemas
essa é a versão de estudantes
nãoq uer mais abrir depois que fiz uma restauração do sistema
Administrator Productivity
