Hi everyone! I have been trying to download and install Maya 2015 to my computer for days now, to no avail. No matter what method I use I get an error message. The Autodesk Download Manager says the file is corrupt and will not load it, browser download does the same thing and the Install Now goes for all of 30 seconds before going to the screen "Installation Complete. Some files failed to install.".....all of them.
I didn't have any issues downloading and installing AutoCAD only hours before I tried Maya. I'm at a loss, please help. Below is my installation log for the most recent attempt at install.
2014/7/9:00:59:48 Kayla KIRROYALE === Setup started on KIRROYALE by Kayla ===
2014/7/9:00:59:48 Kayla KIRROYALE Path_Length: 143
2014/7/9:00:59:48 Kayla KIRROYALE Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/9:00:59:48 Kayla KIRROYALE Launch
2014/7/9:00:59:48 Kayla KIRROYALE CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-48417323 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/9:00:59:48 Kayla KIRROYALE Current Directory C:\Users\Kayla\AppData\Local\Temp\_AIBA5C.tmp
2014/7/9:00:59:53 Kayla KIRROYALE === Setup ended ===
2014/7/9:00:59:50 Kayla KIRROYALE === Setup started on KIRROYALE by Kayla ===
2014/7/9:00:59:50 Kayla KIRROYALE Path_Length: 143
2014/7/9:00:59:50 Kayla KIRROYALE Current Directory C:\Users\Kayla\AppData\Local\Temp\_AIBA5C.tmp
2014/7/9:00:59:50 Kayla KIRROYALE Launch
2014/7/9:00:59:51 Kayla KIRROYALE Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/9:00:59:52 Kayla KIRROYALE PageOpen LaunchDialog
2014/7/9:01:00:01 Kayla KIRROYALE PageOpen LicenseDialog
2014/7/9:01:00:01 Kayla KIRROYALE PageOpen ProductInfoDialog
2014/7/9:01:00:01 Kayla KIRROYALE PageOpen ProductSelectionDialog2
2014/7/9:01:00:05 Kayla KIRROYALE PageOpen FullProgressDialog
2014/7/9:01:00:05 Kayla KIRROYALE Download Skipped VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST200...
2014/7/9:01:00:05 Kayla KIRROYALE Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kayla\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/7/9:01:00:37 Kayla KIRROYALE Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/7/9:01:00:38 Kayla KIRROYALE Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/9:01:00:38 Kayla KIRROYALE Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
