Installation & Licensing
Maya 2015 Installation complete.SomeProducts failed to install- Windows 8.1
3 REPLIES 3
ShamanicHarmonics
1177 Views, 3 Replies
Hi there!
I've read through a bunch of the articles here on this issue (though I didn't see any for 2015, though I imagine the issue is similar). I just downloaded the .exe file from Autodesk for the student version and I need it for a class in 3 days, I was hoping to install now so I can learn some basic features. I uninstalled all my Microsoft Visual C++ (x86) Redistributable files multiple times, rebootedmultiple times, re-downloaded the exe file and tried to install multiple times, all with the same error. I tried to find the setup.ini file, but since all I have right now is the downloaded .exe file I can't seem to find any way to actually locate the setup.ini file so I can follow Travis N.'s instructions for removing the prerequisite requirements. I checked that my .NET 3.5 is enabled in my Windows 8.1, at a total loss, been working on this for hours... below is my log files -
2014/7/11:07:23:54    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:23:54    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:07:23:54    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:23:54    Jeremy82many    JEREMY    Launch
2014/7/11:07:23:54    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:07:23:54    Jeremy82many    JEREMY    Setup    Windows update reboot is pending
2014/7/11:07:27:49    Jeremy82many    JEREMY    Setup    Autodesk Maya 2015    Will restart automatically.
2014/7/11:07:27:49    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:07:32:54    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:32:54    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:07:32:54    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:32:54    Jeremy82many    JEREMY    Launch
2014/7/11:07:32:54    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:07:32:54    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI37CA.tmp
2014/7/11:07:34:36    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:07:33:16    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:33:16    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:07:33:16    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI37CA.tmp
2014/7/11:07:33:16    Jeremy82many    JEREMY    Launch
2014/7/11:07:34:22    Jeremy82many    JEREMY    Download    Play    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:07:34:35    Jeremy82many    JEREMY    Download    Complete    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:07:34:36    Jeremy82many    JEREMY    PageOpen    LaunchDialog
2014/7/11:07:34:59    Jeremy82many    JEREMY    PageOpen    LicenseDialog
2014/7/11:07:34:59    Jeremy82many    JEREMY    PageOpen    ProductInfoDialog
2014/7/11:07:34:59    Jeremy82many    JEREMY    PageOpen    ProductSelectionDialog2
2014/7/11:07:37:56    Jeremy82many    JEREMY    PageOpen    FullProgressDialog
2014/7/11:07:37:58    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    VCREDIST2012X86    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:07:37:58    Jeremy82many    JEREMY    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Download Failed, Installation aborted, Result=1603
2014/7/11:07:37:58    Jeremy82many    JEREMY    PageOpen    InstallCompleteDialog
2014/7/11:07:38:34    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:07:43:52    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:43:52    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:07:43:52    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:43:52    Jeremy82many    JEREMY    Launch
2014/7/11:07:43:52    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:07:43:52    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI4382.tmp
2014/7/11:07:44:01    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:07:43:54    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:43:54    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:07:43:54    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI4382.tmp
2014/7/11:07:43:54    Jeremy82many    JEREMY    Launch
2014/7/11:07:43:57    Jeremy82many    JEREMY    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:07:43:59    Jeremy82many    JEREMY    PageOpen    LaunchDialog
2014/7/11:07:44:06    Jeremy82many    JEREMY    PageOpen    LicenseDialog
2014/7/11:07:44:06    Jeremy82many    JEREMY    PageOpen    ProductInfoDialog
2014/7/11:07:44:06    Jeremy82many    JEREMY    PageOpen    ProductSelectionDialog2
2014/7/11:07:44:12    Jeremy82many    JEREMY    PageOpen    FullProgressDialog
2014/7/11:07:44:13    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    VCREDIST2012X86    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:07:44:13    Jeremy82many    JEREMY    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Download Failed, Installation aborted, Result=1603
2014/7/11:07:44:14    Jeremy82many    JEREMY    PageOpen    InstallCompleteDialog
2014/7/11:07:48:46    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:07:49:40    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:49:40    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:07:49:40    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:49:40    Jeremy82many    JEREMY    Launch
2014/7/11:07:49:40    Jeremy82many    JEREMY    CommandLine
2014/7/11:07:49:40    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI9236.tmp
2014/7/11:07:49:54    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:07:49:55    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:07:53:00    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:53:00    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:07:53:00    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:53:00    Jeremy82many    JEREMY    Launch
2014/7/11:07:53:00    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:07:53:00    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIA0ED.tmp
2014/7/11:07:53:47    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:07:53:01    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:53:01    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:07:53:01    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIA0ED.tmp
2014/7/11:07:53:01    Jeremy82many    JEREMY    Launch
2014/7/11:07:53:46    Jeremy82many    JEREMY    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:07:53:47    Jeremy82many    JEREMY    PageOpen    LaunchDialog
2014/7/11:07:55:12    Jeremy82many    JEREMY    PageOpen    LicenseDialog
2014/7/11:07:55:12    Jeremy82many    JEREMY    PageOpen    ProductInfoDialog
2014/7/11:07:55:12    Jeremy82many    JEREMY    PageOpen    ProductSelectionDialog2
2014/7/11:07:55:25    Jeremy82many    JEREMY    PageOpen    FullProgressDialog
2014/7/11:07:55:28    Jeremy82many    JEREMY    Download    Play    VCREDIST2012X86    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/11:07:55:52    Jeremy82many    JEREMY    Download    Complete    VCREDIST2012X86    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/11:07:55:52    Jeremy82many    JEREMY    Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/7/11:07:56:36    Jeremy82many    JEREMY    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/7/11:07:56:37    Jeremy82many    JEREMY    Download    Play    VCREDIST2012X64    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/11:07:56:44    Jeremy82many    JEREMY    Download    Complete    VCREDIST2012X64    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/11:07:56:44    Jeremy82many    JEREMY    Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/7/11:07:57:42    Jeremy82many    JEREMY    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/7/11:07:57:42    Jeremy82many    JEREMY    Download    Play    DIRECTX    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/7/11:07:57:47    Jeremy82many    JEREMY    Download    Complete    DIRECTX    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/7/11:07:57:47    Jeremy82many    JEREMY    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/7/11:07:57:57    Jeremy82many    JEREMY    Install    DirectX® Runtime    Succeeded
2014/7/11:07:57:57    Jeremy82many    JEREMY    Download    Play    ADAPPLICATIONMANAGER    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/ADAPPLICATI...
2014/7/11:07:58:20    Jeremy82many    JEREMY    Download    Complete    ADAPPLICATIONMANAGER    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/ADAPPLICATI...
2014/7/11:07:58:20    Jeremy82many    JEREMY    Installing Autodesk Application Manager: "C:\Autodesk\WI\Autodesk Maya 2015\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2014/7/11:07:59:29    Jeremy82many    JEREMY    Install    Autodesk Application Manager    Succeeded
2014/7/11:07:59:29    Jeremy82many    JEREMY    Download    Play    MAYA    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:00:01    Jeremy82many    JEREMY    Download    User Pause    MAYA    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:00:01    Jeremy82many    JEREMY    Download    Paused    MAYA    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:51:48    Jeremy82many    JEREMY    Download    User Resume    MAYA    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:51:51    Jeremy82many    JEREMY    Download Error    MAYA    <B>Connection has expired.</B>Please Install Now again from the Autodesk website.     http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:51:52    Jeremy82many    JEREMY    Download    Aborted    MAYA    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:51:52    Jeremy82many    JEREMY    Install    Autodesk® Maya® 2015    Failed    Download Failed, Installation aborted, Result=1603
2014/7/11:08:51:53    Jeremy82many    JEREMY    Rollback    Autodesk Application Manager    Failed    Failure is ignored, Result=1619
2014/7/11:08:51:53    Jeremy82many    JEREMY    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/7/11:08:51:53    Jeremy82many    JEREMY    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Installation aborted, Result=1619
2014/7/11:08:51:53    Jeremy82many    JEREMY    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Installation aborted, Result=1619
2014/7/11:08:51:53    Jeremy82many    JEREMY    PageOpen    InstallCompleteDialog
2014/7/11:09:01:55    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:09:04:23    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:04:23    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:09:04:23    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:09:04:23    Jeremy82many    JEREMY    Launch
2014/7/11:09:04:23    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:09:04:24    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:09:04:24    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIFBE2.tmp
2014/7/11:09:04:31    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:09:04:25    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:04:25    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:09:04:25    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIFBE2.tmp
2014/7/11:09:04:25    Jeremy82many    JEREMY    Launch
2014/7/11:09:04:28    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:09:04:28    Jeremy82many    JEREMY    Connection has expired. Please reconnect to site.2014/7/11:09:04:32    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:09:07:50    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:07:50    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:09:07:50    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:09:07:50    Jeremy82many    JEREMY    Launch
2014/7/11:09:07:50    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:09:07:50    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI20EF.tmp
2014/7/11:09:08:37    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:09:07:51    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:07:51    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:09:07:51    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI20EF.tmp
2014/7/11:09:07:51    Jeremy82many    JEREMY    Launch
2014/7/11:09:07:54    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:09:07:54    Jeremy82many    JEREMY    Connection has expired. Please reconnect to site.2014/7/11:09:08:37    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:09:22:53    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:22:53    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:09:22:53    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:09:22:53    Jeremy82many    JEREMY    Launch
2014/7/11:09:22:53    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:09:22:53    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIBE7B.tmp
2014/7/11:09:23:33    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:09:22:56    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:22:56    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:09:22:56    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIBE7B.tmp
2014/7/11:09:22:56    Jeremy82many    JEREMY    Launch
2014/7/11:09:23:33    Jeremy82many    JEREMY    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:09:23:33    Jeremy82many    JEREMY    PageOpen    LaunchDialog
2014/7/11:09:23:51    Jeremy82many    JEREMY    PageOpen    LicenseDialog
2014/7/11:09:23:51    Jeremy82many    JEREMY    PageOpen    ProductInfoDialog
2014/7/11:09:23:51    Jeremy82many    JEREMY    PageOpen    ProductSelectionDialog2
2014/7/11:09:25:08    Jeremy82many    JEREMY    PageOpen    FullProgressDialog
2014/7/11:09:25:10    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    VCREDIST2012X86    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:09:25:10    Jeremy82many    JEREMY    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Download Failed, Installation aborted, Result=1603
2014/7/11:09:25:10    Jeremy82many    JEREMY    PageOpen    InstallCompleteDialog
2014/7/11:09:46:47    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:09:53:47    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:53:47    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:09:53:47    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:09:53:47    Jeremy82many    JEREMY    Launch
2014/7/11:09:53:47    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:09:53:47    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIB74B.tmp
2014/7/11:09:55:17    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:09:53:48    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:53:48    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:09:53:48    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIB74B.tmp
2014/7/11:09:53:48    Jeremy82many    JEREMY    Launch
2014/7/11:09:54:33    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:09:54:33    Jeremy82many    JEREMY    Connection has expired. Please reconnect to site.2014/7/11:09:55:18    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:00:28    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:00:28    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:00:28    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:00:28    Jeremy82many    JEREMY    Launch
2014/7/11:10:00:28    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:00:28    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AID545.tmp
2014/7/11:10:00:34    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:00:29    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:00:29    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:00:29    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AID545.tmp
2014/7/11:10:00:29    Jeremy82many    JEREMY    Launch
2014/7/11:10:00:30    Jeremy82many    JEREMY    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:10:00:34    Jeremy82many    JEREMY    PageOpen    LaunchDialog
2014/7/11:10:02:18    Jeremy82many    JEREMY    PageOpen    LicenseDialog
2014/7/11:10:02:18    Jeremy82many    JEREMY    PageOpen    ProductInfoDialog
2014/7/11:10:02:18    Jeremy82many    JEREMY    PageOpen    ProductSelectionDialog2
2014/7/11:10:02:23    Jeremy82many    JEREMY    PageOpen    FullProgressDialog
2014/7/11:10:02:24    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    VCREDIST2012X86    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:10:02:24    Jeremy82many    JEREMY    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Download Failed, Installation aborted, Result=1603
2014/7/11:10:02:24    Jeremy82many    JEREMY    PageOpen    InstallCompleteDialog
2014/7/11:10:22:38    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:27:22    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:27:22    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:27:22    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:27:22    Jeremy82many    JEREMY    Launch
2014/7/11:10:27:22    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:27:22    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AID2D2.tmp
2014/7/11:10:27:27    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:27:23    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:27:23    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:27:23    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AID2D2.tmp
2014/7/11:10:27:23    Jeremy82many    JEREMY    Launch
2014/7/11:10:27:24    Jeremy82many    JEREMY    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:10:27:27    Jeremy82many    JEREMY    PageOpen    LaunchDialog
2014/7/11:10:27:41    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:28:07    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:28:07    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:28:07    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:28:07    Jeremy82many    JEREMY    Launch
2014/7/11:10:28:07    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:28:07    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI8113.tmp
2014/7/11:10:28:14    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:28:08    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:28:08    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:28:08    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI8113.tmp
2014/7/11:10:28:08    Jeremy82many    JEREMY    Launch
2014/7/11:10:28:11    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:10:28:11    Jeremy82many    JEREMY    Connection has expired. Please reconnect to site.2014/7/11:10:28:15    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:29:27    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:29:27    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:29:27    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:29:27    Jeremy82many    JEREMY    Launch
2014/7/11:10:29:27    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:29:27    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIB9F1.tmp
2014/7/11:10:29:31    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:29:28    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:29:28    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:29:28    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIB9F1.tmp
2014/7/11:10:29:28    Jeremy82many    JEREMY    Launch
2014/7/11:10:29:28    Jeremy82many    JEREMY    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:10:29:29    Jeremy82many    JEREMY    PageOpen    LaunchDialog
2014/7/11:10:29:37    Jeremy82many    JEREMY    PageOpen    LicenseDialog
2014/7/11:10:29:37    Jeremy82many    JEREMY    PageOpen    ProductInfoDialog
2014/7/11:10:29:37    Jeremy82many    JEREMY    PageOpen    ProductSelectionDialog2
2014/7/11:10:29:41    Jeremy82many    JEREMY    PageOpen    FullProgressDialog
2014/7/11:10:29:43    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    VCREDIST2012X86    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:10:29:43    Jeremy82many    JEREMY    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Download Failed, Installation aborted, Result=1603
2014/7/11:10:29:43    Jeremy82many    JEREMY    PageOpen    InstallCompleteDialog
2014/7/11:10:36:24    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:37:29    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:37:29    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:37:29    Jeremy82many    JEREMY    Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:37:29    Jeremy82many    JEREMY    Launch
2014/7/11:10:37:29    Jeremy82many    JEREMY    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:37:29    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI1638.tmp
2014/7/11:10:37:35    Jeremy82many    JEREMY    === Setup ended ===
2014/7/11:10:37:30    Jeremy82many    JEREMY    === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:37:30    Jeremy82many    JEREMY    Path_Length: 143
2014/7/11:10:37:30    Jeremy82many    JEREMY    Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI1638.tmp
2014/7/11:10:37:30    Jeremy82many    JEREMY    Launch
2014/7/11:10:37:31    Jeremy82many    JEREMY    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:10:37:33    Jeremy82many    JEREMY    PageOpen    LaunchDialog
2014/7/11:10:37:38    Jeremy82many    JEREMY    PageOpen    LicenseDialog
2014/7/11:10:37:38    Jeremy82many    JEREMY    PageOpen    ProductInfoDialog
2014/7/11:10:37:38    Jeremy82many    JEREMY    PageOpen    ProductSelectionDialog2
2014/7/11:10:37:43    Jeremy82many    JEREMY    PageOpen    FullProgressDialog
2014/7/11:10:37:45    Jeremy82many    JEREMY    Download Error    Connection has expired. Please reconnect to site.    VCREDIST2012X86    http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:10:37:45    Jeremy82many    JEREMY    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Download Failed, Installation aborted, Result=1603
Shamanic Harmonics
Psychedelic Art & Jewelry Laboratory
www.ShamanicHarmonics.com
3 REPLIES 3
I do see that I forgot to mention I also disabled my antivirus, firewall, and UAC.
Shamanic Harmonics
After somemore searching I found that the answer to this thread, with the installer downloads solved my problems 🙂
http://forums.autodesk.com/t5/Installation-Licensing/Trouble-on-Maya-installation/td-p/5134880/page/...
Shamanic Harmonics
Thank you for sharing your solution! Smiley Happy
Jessica Thrasher
Administrator Productivity
