I've been trying to install since yesterday and it's bugging me out. I have an important project to submit by Monday and I can't seem to install it. My GPA lies entirely on this. please reply and help me ASAP. I have to submit this or I'll be debared from my course.
=== Setup started on ABMI_ by Aaqmal ===
2014/11/7:18:58:46 Aaqmal ABMI_ Path_Length: 151
2014/11/7:18:58:46 Aaqmal ABMI_ Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/11/7:18:58:46 Aaqmal ABMI_ Launch
2014/11/7:18:58:46 Aaqmal ABMI_ CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-52198358 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/7:18:58:46 Aaqmal ABMI_ Current Directory C:\Users\Aaqmal\AppData\Local\Temp\_AICF08.tmp
2014/11/7:18:59:25 Aaqmal ABMI_ === Setup ended ===
2014/11/7:18:58:50 Aaqmal ABMI_ === Setup started on ABMI_ by Aaqmal ===
2014/11/7:18:58:50 Aaqmal ABMI_ Path_Length: 151
2014/11/7:18:58:50 Aaqmal ABMI_ Current Directory C:\Users\Aaqmal\AppData\Local\Temp\_AICF08.tmp
2014/11/7:18:58:50 Aaqmal ABMI_ Launch
2014/11/7:18:59:08 Aaqmal ABMI_ Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64...
2014/11/7:18:59:25 Aaqmal ABMI_ PageOpen LaunchDialog
2014/11/7:19:05:44 Aaqmal ABMI_ === Setup started on ABMI_ by Aaqmal ===
2014/11/7:19:05:44 Aaqmal ABMI_ Path_Length: 151
2014/11/7:19:05:44 Aaqmal ABMI_ Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/11/7:19:05:44 Aaqmal ABMI_ Launch
2014/11/7:19:05:44 Aaqmal ABMI_ CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-52198358 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/7:19:05:44 Aaqmal ABMI_ Current Directory C:\Users\Aaqmal\AppData\Local\Temp\_AI344D.tmp
2014/11/7:19:05:47 Aaqmal ABMI_ === Setup ended ===
2014/11/7:19:05:45 Aaqmal ABMI_ === Setup started on ABMI_ by Aaqmal ===
2014/11/7:19:05:45 Aaqmal ABMI_ Path_Length: 151
2014/11/7:19:05:45 Aaqmal ABMI_ Current Directory C:\Users\Aaqmal\AppData\Local\Temp\_AI344D.tmp
2014/11/7:19:05:45 Aaqmal ABMI_ Launch
2014/11/7:19:05:45 Aaqmal ABMI_ Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64...
2014/11/7:19:05:47 Aaqmal ABMI_ PageOpen LaunchDialog
2014/11/7:19:05:53 Aaqmal ABMI_ PageOpen LicenseDialog
2014/11/7:19:05:53 Aaqmal ABMI_ PageOpen ProductInfoDialog
2014/11/7:19:05:53 Aaqmal ABMI_ PageOpen ProductSelectionDialog2
2014/11/7:19:05:57 Aaqmal ABMI_ PageOpen FullProgressDialog
2014/11/7:19:05:57 Aaqmal ABMI_ Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.t...
2014/11/7:19:05:57 Aaqmal ABMI_ Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/7:19:06:59 Aaqmal ABMI_ Install DirectX® Runtime Succeeded
2014/11/7:19:07:00 Aaqmal ABMI_ Download Play Maya http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-U...
2014/11/7:19:08:22 Aaqmal ABMI_ Download Aborted Maya http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-U...
2014/11/7:19:08:22 Aaqmal ABMI_ Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/11/7:19:08:22 Aaqmal ABMI_ Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/11/7:19:08:22 Aaqmal ABMI_ PageOpen InstallCompleteDialog
2014/11/7:19:14:13 Aaqmal ABMI_ === Setup ended ===
2014/11/7:20:41:38 Aaqmal ABMI_ === Setup started on ABMI_ by Aaqmal ===
2014/11/7:20:41:38 Aaqmal ABMI_ Path_Length: 151
2014/11/7:20:41:38 Aaqmal ABMI_ Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/11/7:20:41:38 Aaqmal ABMI_ Launch
2014/11/7:20:41:38 Aaqmal ABMI_ CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-52198358 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/7:20:41:38 Aaqmal ABMI_ Current Directory C:\Users\Aaqmal\AppData\Local\Temp\_AI9BED.tmp
2014/11/7:20:41:44 Aaqmal ABMI_ === Setup ended ===
2014/11/7:20:41:40 Aaqmal ABMI_ === Setup started on ABMI_ by Aaqmal ===
2014/11/7:20:41:40 Aaqmal ABMI_ Path_Length: 151
2014/11/7:20:41:40 Aaqmal ABMI_ Current Directory C:\Users\Aaqmal\AppData\Local\Temp\_AI9BED.tmp
2014/11/7:20:41:40 Aaqmal ABMI_ Launch
2014/11/7:20:41:42 Aaqmal ABMI_ Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64...
2014/11/7:20:41:44 Aaqmal ABMI_ PageOpen LaunchDialog
2014/11/7:20:42:15 Aaqmal ABMI_ PageOpen LicenseDialog
2014/11/7:20:42:15 Aaqmal ABMI_ PageOpen ProductInfoDialog
2014/11/7:20:42:15 Aaqmal ABMI_ PageOpen ProductSelectionDialog2
2014/11/7:20:42:46 Aaqmal ABMI_ PageOpen FullProgressDialog
2014/11/7:20:42:46 Aaqmal ABMI_ Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.t...
2014/11/7:20:42:46 Aaqmal ABMI_ Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/7:20:43:30 Aaqmal ABMI_ Install DirectX® Runtime Succeeded
2014/11/7:20:43:31 Aaqmal ABMI_ Download Play Maya http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-U...
2014/11/7:20:44:54 Aaqmal ABMI_ Download Aborted Maya http://edutrial.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-U...
2014/11/7:20:44:54 Aaqmal ABMI_ Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/11/7:20:44:54 Aaqmal ABMI_ Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Hello. You appear to possibly failing on the actual download.
Download from here, instead:
-then run the installer. It will avoid the download as the cause.
Thank you for taking part in our community!
