Hello everyone!
I have recently tried to download Maya 2015 I keep on getting the same error page (look at jpeg image attached). I am running Windows 7 64 bit and my subsrcription is with my college. I have tried turning off my firewall and my virus protection, re installing and still nothing. Please help out!
Ollie
Solved by ollie0070. Go to Solution.
Hi @ollie0070
Please, follow the steps detailed on this solution.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Post the installation log (the blue link on your failure page) and it will help determine the failure.
@TravisNave wrote:Post the installation log (the blue link on your failure page) and it will help determine the failure.
I already uninstalled the program that was causing the error but still nothing here it is anyways:
2014/9/16:14:30:31 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:14:30:31 Ollie OLLIE-PC Path_Length: 143
2014/9/16:14:30:31 Ollie OLLIE-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/16:14:30:31 Ollie OLLIE-PC Launch
2014/9/16:14:30:31 Ollie OLLIE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50328977 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/16:14:30:31 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AI292.tmp
2014/9/16:14:31:33 Ollie OLLIE-PC === Setup ended ===
2014/9/16:14:30:33 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:14:30:33 Ollie OLLIE-PC Path_Length: 143
2014/9/16:14:30:33 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AI292.tmp
2014/9/16:14:30:33 Ollie OLLIE-PC Launch
2014/9/16:14:31:24 Ollie OLLIE-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/16:14:31:32 Ollie OLLIE-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/16:14:31:33 Ollie OLLIE-PC PageOpen LaunchDialog
2014/9/16:14:32:47 Ollie OLLIE-PC PageOpen LicenseDialog
2014/9/16:14:32:47 Ollie OLLIE-PC PageOpen ProductSelectionDialog2
2014/9/16:14:32:53 Ollie OLLIE-PC PageOpen LicenseDialog
2014/9/16:14:32:53 Ollie OLLIE-PC PageOpen LaunchDialog
2014/9/16:14:32:57 Ollie OLLIE-PC PageOpen LicenseDialog
2014/9/16:14:32:57 Ollie OLLIE-PC PageOpen ProductInfoDialog
2014/9/16:14:32:57 Ollie OLLIE-PC PageOpen ProductSelectionDialog2
2014/9/16:14:33:28 Ollie OLLIE-PC PageOpen FullProgressDialog
2014/9/16:14:33:29 Ollie OLLIE-PC Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST200...
2014/9/16:14:33:30 Ollie OLLIE-PC Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST200...
2014/9/16:14:33:30 Ollie OLLIE-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ollie\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/9/16:14:33:47 Ollie OLLIE-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/9/16:14:33:48 Ollie OLLIE-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/16:14:33:48 Ollie OLLIE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/9/16:14:33:48 Ollie OLLIE-PC PageOpen InstallCompleteDialog
2014/9/16:14:36:40 Ollie OLLIE-PC === Setup ended ===
2014/9/16:14:36:49 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:14:36:49 Ollie OLLIE-PC Path_Length: 143
2014/9/16:14:36:49 Ollie OLLIE-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/16:14:36:49 Ollie OLLIE-PC Launch
2014/9/16:14:36:49 Ollie OLLIE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50328977 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/16:14:36:49 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AIC8AE.tmp
2014/9/16:14:36:53 Ollie OLLIE-PC === Setup ended ===
2014/9/16:14:36:51 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:14:36:51 Ollie OLLIE-PC Path_Length: 143
2014/9/16:14:36:51 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AIC8AE.tmp
2014/9/16:14:36:51 Ollie OLLIE-PC Launch
2014/9/16:14:36:52 Ollie OLLIE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/16:14:36:52 Ollie OLLIE-PC PageOpen LaunchDialog
2014/9/16:14:43:04 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:14:43:04 Ollie OLLIE-PC Path_Length: 143
2014/9/16:14:43:04 Ollie OLLIE-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/16:14:43:04 Ollie OLLIE-PC Launch
2014/9/16:14:43:04 Ollie OLLIE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50328977 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/16:14:43:04 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AI7EB4.tmp
2014/9/16:14:43:06 Ollie OLLIE-PC === Setup ended ===
2014/9/16:14:43:05 Ollie OLLIE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/16:14:43:05 Ollie OLLIE-PC PageOpen LaunchDialog
2014/9/16:14:43:13 Ollie OLLIE-PC PageOpen LicenseDialog
2014/9/16:14:43:13 Ollie OLLIE-PC PageOpen ProductInfoDialog
2014/9/16:14:43:13 Ollie OLLIE-PC PageOpen ProductSelectionDialog2
2014/9/16:14:43:17 Ollie OLLIE-PC PageOpen FullProgressDialog
2014/9/16:14:43:18 Ollie OLLIE-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/16:14:43:18 Ollie OLLIE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/9/16:14:43:18 Ollie OLLIE-PC PageOpen InstallCompleteDialog
2014/9/16:14:45:04 Ollie OLLIE-PC === Setup ended ===
2014/9/16:14:45:28 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:14:45:28 Ollie OLLIE-PC Path_Length: 143
2014/9/16:14:45:28 Ollie OLLIE-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/16:14:45:28 Ollie OLLIE-PC Launch
2014/9/16:14:45:28 Ollie OLLIE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50328977 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/16:14:45:28 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AIB454.tmp
2014/9/16:14:45:30 Ollie OLLIE-PC === Setup ended ===
2014/9/16:14:45:29 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:14:45:29 Ollie OLLIE-PC Path_Length: 143
2014/9/16:14:45:29 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AIB454.tmp
2014/9/16:14:45:29 Ollie OLLIE-PC Launch
2014/9/16:14:45:29 Ollie OLLIE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/16:14:45:29 Ollie OLLIE-PC PageOpen LaunchDialog
2014/9/16:14:45:36 Ollie OLLIE-PC PageOpen LicenseDialog
2014/9/16:14:45:36 Ollie OLLIE-PC PageOpen ProductInfoDialog
2014/9/16:14:45:36 Ollie OLLIE-PC PageOpen ProductSelectionDialog2
2014/9/16:14:45:57 Ollie OLLIE-PC PageOpen FullProgressDialog
2014/9/16:14:45:59 Ollie OLLIE-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/16:14:45:59 Ollie OLLIE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/9/16:14:45:59 Ollie OLLIE-PC PageOpen InstallCompleteDialog
2014/9/16:14:46:22 Ollie OLLIE-PC === Setup ended ===
2014/9/16:15:06:56 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:15:06:56 Ollie OLLIE-PC Path_Length: 143
2014/9/16:15:06:56 Ollie OLLIE-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/16:15:06:56 Ollie OLLIE-PC Launch
2014/9/16:15:06:56 Ollie OLLIE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50328977 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/16:15:06:56 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AI5AA1.tmp
2014/9/16:15:07:00 Ollie OLLIE-PC === Setup ended ===
2014/9/16:15:06:57 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:15:06:57 Ollie OLLIE-PC Path_Length: 143
2014/9/16:15:06:57 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AI5AA1.tmp
2014/9/16:15:06:57 Ollie OLLIE-PC Launch
2014/9/16:15:06:58 Ollie OLLIE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/16:15:06:58 Ollie OLLIE-PC PageOpen LaunchDialog
2014/9/16:15:07:04 Ollie OLLIE-PC PageOpen LicenseDialog
2014/9/16:15:07:04 Ollie OLLIE-PC PageOpen ProductInfoDialog
2014/9/16:15:07:04 Ollie OLLIE-PC PageOpen ProductSelectionDialog2
2014/9/16:15:07:18 Ollie OLLIE-PC PageOpen FullProgressDialog
2014/9/16:15:07:19 Ollie OLLIE-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/16:15:07:19 Ollie OLLIE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/9/16:15:07:19 Ollie OLLIE-PC PageOpen InstallCompleteDialog
2014/9/16:15:17:16 Ollie OLLIE-PC === Setup ended ===
2014/9/16:16:44:40 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:16:44:40 Ollie OLLIE-PC Path_Length: 143
2014/9/16:16:44:40 Ollie OLLIE-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/16:16:44:40 Ollie OLLIE-PC Launch
2014/9/16:16:44:40 Ollie OLLIE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50328977 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/16:16:44:40 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AID435.tmp
2014/9/16:16:44:49 Ollie OLLIE-PC === Setup ended ===
2014/9/16:16:44:42 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:16:44:42 Ollie OLLIE-PC Path_Length: 143
2014/9/16:16:44:42 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AID435.tmp
2014/9/16:16:44:42 Ollie OLLIE-PC Launch
2014/9/16:16:44:43 Ollie OLLIE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/16:16:44:47 Ollie OLLIE-PC PageOpen LaunchDialog
2014/9/16:16:44:54 Ollie OLLIE-PC PageOpen LicenseDialog
2014/9/16:16:44:54 Ollie OLLIE-PC PageOpen ProductInfoDialog
2014/9/16:16:44:54 Ollie OLLIE-PC PageOpen ProductSelectionDialog2
2014/9/16:16:44:58 Ollie OLLIE-PC PageOpen FullProgressDialog
2014/9/16:16:45:00 Ollie OLLIE-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/16:16:45:00 Ollie OLLIE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/9/16:16:45:00 Ollie OLLIE-PC PageOpen InstallCompleteDialog
2014/9/16:16:50:03 Ollie OLLIE-PC === Setup ended ===
2014/9/16:16:55:02 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:16:55:02 Ollie OLLIE-PC Path_Length: 143
2014/9/16:16:55:02 Ollie OLLIE-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/16:16:55:02 Ollie OLLIE-PC Launch
2014/9/16:16:55:02 Ollie OLLIE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50328977 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/16:16:55:02 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AI5047.tmp
2014/9/16:16:55:04 Ollie OLLIE-PC === Setup ended ===
2014/9/16:16:55:03 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:16:55:03 Ollie OLLIE-PC Path_Length: 143
2014/9/16:16:55:03 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AI5047.tmp
2014/9/16:16:55:03 Ollie OLLIE-PC Launch
2014/9/16:16:55:03 Ollie OLLIE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/16:16:55:03 Ollie OLLIE-PC PageOpen LaunchDialog
2014/9/16:16:55:10 Ollie OLLIE-PC PageOpen LicenseDialog
2014/9/16:16:55:10 Ollie OLLIE-PC PageOpen ProductInfoDialog
2014/9/16:16:55:10 Ollie OLLIE-PC PageOpen ProductSelectionDialog2
2014/9/16:16:55:14 Ollie OLLIE-PC PageOpen FullProgressDialog
2014/9/16:16:55:15 Ollie OLLIE-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/16:16:55:15 Ollie OLLIE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/9/16:16:55:15 Ollie OLLIE-PC PageOpen InstallCompleteDialog
2014/9/16:16:55:29 Ollie OLLIE-PC === Setup ended ===
2014/9/16:17:01:40 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:17:01:40 Ollie OLLIE-PC Path_Length: 143
2014/9/16:17:01:40 Ollie OLLIE-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/16:17:01:40 Ollie OLLIE-PC Launch
2014/9/16:17:01:40 Ollie OLLIE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-50328977 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/16:17:01:40 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AIBC6B.tmp
2014/9/16:17:01:48 Ollie OLLIE-PC === Setup ended ===
2014/9/16:17:01:42 Ollie OLLIE-PC === Setup started on OLLIE-PC by Ollie ===
2014/9/16:17:01:42 Ollie OLLIE-PC Path_Length: 143
2014/9/16:17:01:42 Ollie OLLIE-PC Current Directory C:\Users\Ollie\AppData\Local\Temp\_AIBC6B.tmp
2014/9/16:17:01:42 Ollie OLLIE-PC Launch
2014/9/16:17:01:43 Ollie OLLIE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/16:17:01:44 Ollie OLLIE-PC PageOpen LaunchDialog
2014/9/16:17:01:55 Ollie OLLIE-PC PageOpen LicenseDialog
2014/9/16:17:01:55 Ollie OLLIE-PC PageOpen ProductInfoDialog
2014/9/16:17:01:55 Ollie OLLIE-PC PageOpen ProductSelectionDialog2
2014/9/16:17:02:16 Ollie OLLIE-PC PageOpen FullProgressDialog
2014/9/16:17:02:18 Ollie OLLIE-PC Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/16:17:02:18 Ollie OLLIE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/16:17:02:18 Ollie OLLIE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
It is a download failure.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Still is not working. I get another error and I have tried it mutiple times.
@TravisNave wrote:Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe 2014/9/16:17:02:18 Ollie OLLIE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603It is a download failure.
Sorry, I viewed the last post on mobile and it didn't show the attachment. Looks like you are missing the 2nd part of your Maya download. Did you get the whole thing?
So close but yet another error 😞 this is the farthest it gets before it stops and a new error pops up (image attached with error and progress). It is saying I need to verify that a certain file is there which it is not. It was happily downloading until this.
Got it working! 😄
SOLUTION: Copied the .bat and made a new one and renamed it a .dll here is step-by-step:
