Installation & Licensing
[Maya 2015] Copy error during installation
2 REPLIES 2
ImDaKu
308 Views, 2 Replies
Hi. I tried to install Maya 2015 but i get an Error (maya.PNG).
As first:
- the file exists
- i copied the file & folder to different locations on the same disk and to other disks, without errors
- i let extract the downloaded file to different locations, without errors and tried to install from there
Is it possible to get the md5 hash of this file or from Autodesk_Maya_2015_dlm.sfx.exe to compare?
Rgds.
2 REPLIES 2
TravisNave
in reply to: ImDaKu
Make sure you install with anti-virus disabled, UAC off, and local admin rights.
If the problem still exisits, I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
ImDaKu
in reply to: TravisNave
Hi.
I downloaded it again (http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/DLM/Autodesk_Maya_2015_dlm.sfx.exe) and the same error comes up.
But now i have another Problem.
The next download stops and this is the error msg: "Connection closed at byte 855638016".
WHY???
Administrator Productivity
