Hi. I tried to install Maya 2015 but i get an Error ().
As first:
- the file exists
- i copied the file & folder to different locations on the same disk and to other disks, without errors
- i let extract the downloaded file to different locations, without errors and tried to install from there
Is it possible to get the md5 hash of this file or from Autodesk_Maya_2015_dlm.sfx.exe to compare?
Rgds.
Make sure you install with anti-virus disabled, UAC off, and local admin rights.
If the problem still exisits, I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Hi.
I downloaded it again (http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/DLM/Autodesk_Maya_2015_dlm.sfx.exe) and the same error comes up.
But now i have another Problem.
The next download stops and this is the error msg: "Connection closed at byte 855638016".
WHY???
