Installation & Licensing
Active Member
Corey.Ballantoni
Message 1 of 9 (3,057 Views)
Maya 2014 Unable to Start Correctly (0xc000007b)
3057 Views, 8 Replies
01-29-2014 02:03 AM
I just recently installed Maya 2014 and I get the pop up that it was unable to start. I also get that same pop up for each of the accompanying software such as MatchMover.
I've search all over the net and Autodesk help and several people have had this issue. Some have fixed it with DirectX and Microsoft Visual C++ 2010 Service Pack 1 installs. Another solution was to install the latest Nvidia GeForce Drivers. And some couldn't get it to work after any of those solutions. That is where I am now. Below you'll find the hardware and OS I am running.
Any ideas what I could do? :smileysad:
-Windows 7 Ultimate 64 Bit SP1
-Nvidia GeForce GTX 680 Video Card
-Intel Desktop Board Extreme Series LGA 1155 DDR3 2400 Motherboard DZ77GAL-70K
-Intel Core i7-3770 Quad-Core Processor 3.4 GHz 4 Core LGA 1155 - BX80637I73770
-Crucial m4 256GB 2.5-Inch Solid State Drive SATA 6Gb/s CT256M4SSD2
-Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ16GX3M2A1600C10)
Try the below solution
1.) Search the folder you installed the product from for a file called MSVCR100.DLL. If you find multiple copies select one with a file size of 809 KB
2.) Copy MSVCR100.DLL from the location in the install folder
Paste it into the following folders
C:\Windows\System32\
C:\windows\Syswow64
say yes to replacing the file
3.) Reboot your system and try lunching the product again.
Since I couldn't locate the msvcr100.dll with file size 809 kb on my PC I found it on the net located here:
http://www.opendll.com/index.php?search=msvcr100.dll
I swapped them out and success! Everything works!
Thank you so much!
Product Support
brad.hurley
Message 2 of 9 (3,036 Views)
Re: Maya 2014 Unable to Start Correctly (0xc000007b)
01-29-2014 06:05 AM in reply to: Corey.Ballantoni
Hello and welcome to the community!
Based on the error you provided it sounds like you are experiencing corruption with the .exe file. To resolve this issue please uninstall Maya and MatchMoverapp using the MS fix it tool.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
1.) Click the "Run now" button in the Fix-it box.
2.) Accept the License Agreement.
3.) Choose the option "Detect Problems and let me select fixes to apply".
4.) Select "Uninstalling".
5.) When the list of installed programs populates, select the one from the list you are unable to reinstall and then click Next and Yes.
6.) When the tool completes there may be remnants left so please delete the directory where the product was installed.
Prior to installing the software please follow steps 1-4 from the link.
Quick Start: General installation workflow.
http://upandready.typepad.com/up_and_ready/2013/04/quick-start-general-installation-workflow.html
After completing the steps from the link please reinstall Maya and MatchMoverapp.
BHurley
Active Member
Corey.Ballantoni
Message 3 of 9 (3,026 Views)
01-29-2014 09:51 PM in reply to: brad.hurley
Well I was really hopeful but unfortunately after all the changes specified it still is giving me the error.
I disabled all the anti virus software, diabled UAC, added the registry keys per this page (http://upandready.typepad.com/up_and_ready/2012/03/general-systems-windows-7-administrator-tips-tric... and ran the install as an administrator. I also emptied the temp folder. So I have all the install log files available.
Active Member
Corey.Ballantoni
Message 4 of 9 (3,017 Views)
01-30-2014 02:20 AM in reply to: Corey.Ballantoni
So I kept trying several times and still no luck...
Here's the programs installed after downloading the software (Autodesk_Maya_2014_dlm.sfx.exe) and installing again:
Below are the pop ups I get when they fail to open. The only applications that appear to work are the ones under the Autodesk Backburner 2014.
Composite 2014
MatchMover 2014
FCheck
License Transfer Utility
Maya 2014
Product Support
asburyj
Message 5 of 9 (3,004 Views)
01-30-2014 05:01 PM in reply to: Corey.Ballantoni
C:\windows\Syswow64
Jeffry Asbury
Active Member
Corey.Ballantoni
Message 6 of 9 (2,996 Views)
01-30-2014 07:19 PM in reply to: asburyj
Found the file in the setup folder ...Autodesk\Autodesk_Maya_2014_dlm\Setup\msvcr100.dll, but not anywhere else in the Autodesk installation folder.
I only found one and its file size is 753 kb. I still tried copying it over to the folders specified and still no luck. Same problem as before.
Active Member
Corey.Ballantoni
Message 7 of 9 (2,994 Views)
01-30-2014 07:28 PM in reply to: asburyj
I also just tried installing the recommended Maya tested video card drivers for my Nvidia Geforce 680 which shows version 320.49.
I had the latest version 332.21 installed. And still with the older tested drivers I'm getting the same errors.
Active Member
Corey.Ballantoni
Message 8 of 9 (2,985 Views)
01-30-2014 08:04 PM in reply to: asburyj
Tried installing Maya 2013 and the same result remains. All the same errors as before.
Active Member
Corey.Ballantoni
Message 9 of 9 (2,981 Views)
01-30-2014 09:00 PM in reply to: asburyj
Thank you so much!
