Installation & Licensing
Maya 2014, Some products failed to install
1 REPLY 1
leducan
666 Views, 1 Reply
Hello!
I really need some help!!
I have tryed to install Maya 2014 several time on a new computer without any success. I'm running on Windows 8.1 Pro,  i7-4820k 64 bit.
Here are some of solutions suggested on this forum that I have tryed;
- I have disabled the internet security
- I Disabled the User Account Control (UAC)
- I uninstalled the microsoft c++
- I deleted the temp folder
- I cleaned the registry
- I have tryed "Download Now", "Install Now", "Browser Download" and I downloaded the software throught the Virtual Agent "Ask" menu too.
Attached you'll find the Log files
1 REPLY 1
TravisNave
in reply to: leducan
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
Install	Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)	Failed	Installation aborted, Result=1603
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
