I'm a long time Maya user, since version 1.5, but I've suddenly starting having problems with my rendering.
No matter what I do I always get this error in the log's.
Starting "/Applications/Autodesk/maya2014/Maya 2014.app/Contents/bin/maya"
// Maya exited with status 255
I've tried deleting my Pref but that hasn't done anything.
Maya renders just fine in the program just not in Batch. This is for Maya Software and Mental Ray.
Any help would be greatly appreciated.
Best regards,
Matt
Is this happening on all your files or just one particular file?
Has it worked previous in Maya 2014 and has just stopped working or has it never worked with 2014?
Are you able to attach the entire render log so we can take a closer look at whats going on?
Cheers,
Karen
I just downloaded a student version of Maya 2013. I have used earlier versions of Maya in the past without any problems. For some reason, this new version will not let me render. I keep getting the following message: // Warning: The post-processing failed while attempting to rename file /Users/pattyharris/Documents/maya/projects/default/images/tmp/scene1.qt.tmp to /Users/pattyharris/Documents/maya/projects/default/images/tmp/scene1.qt.The operating system reported this error: "No such file or directory".The problem may be due to improper file permissions, file in use, or a full disk.The results of post-processing on this image may be incorrect.
Any ideas how I can fix this? Please help.
best,
Patty
