Installation & Licensing
TsahiReznik2979
Message 1 of 18 (2,154 Views)
Maya 2014 LTU doesn't open
2154 Views, 17 Replies
06-18-2013 11:05 AM
I'm trying to reinstall Maya 2014.
I exported the license with LTU before I uninstalled.
Now, after the new installation the LTU doesn't even open.
I tried re-activating the product online with the original request code I got in the mail,
but it tells me the code is not correct.
Can some one help? This is quite urgent.
Can you please try the suggestions in this post
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wow, that actually worked! Thank you!
So just to make it clear for other users encountering this...
It is the solution by  nachanok_rim in this forum post :
[HKEY_CLASSES_ROOT\*\shell\runas]
@="Take Ownership"
"NoWorkingDirectory"=""
[HKEY_CLASSES_ROOT\*\shell\runas\command]
@="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
"IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
[HKEY_CLASSES_ROOT\Directory\shell\runas]
@="Take Ownership"
[HKEY_CLASSES_ROOT\Directory\shell\runas\command]
@="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
"IsolatedCommand"="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
then save it name Take Ownership.reg
then click on it and click Yes
Now you can Unlock folder that have key pic on it
go to C:\ProgramData
and right click on Autodesk select Take Ownership
then refesh.Now you can see the key pic disappear
do this the same with FLEXNet Folder (same location)
TravisNave
Message 2 of 18 (2,152 Views)
Re: Maya 2014 LTU doesn't open
06-18-2013 11:22 AM in reply to: TsahiReznik2979
Forget the LTU.  It fails 11 out of 10 times.
Just reactivate on your other computer as your 2nd use activation, per the EULA.
If it won't activate automagically, then contact Autodesk Activations for a new activation code.  Your old one from the other computer won't work.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and the request code.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Employee
ankushved
Message 3 of 18 (2,140 Views)
06-18-2013 09:48 PM in reply to: TsahiReznik2979
Which Product key/ product code are you using? It should be using 657F1 for Maya 2014.
Thanks & Regards,
Ankush Ved
Employee
ankushved
Message 4 of 18 (2,139 Views)
06-18-2013 09:51 PM in reply to: TsahiReznik2979
Have a look at this document as well, probably will help you out:
http://docs.autodesk.com/INSTALL_LICENSE/2014/ENU/Autodesk%20Installation%20Help/files/GUID-D5F19435...
Thanks & Regards,
Ankush Ved
TsahiReznik2979
Message 5 of 18 (2,133 Views)
06-18-2013 11:50 PM in reply to: ankushved
Yes. That's the product key I used during export.
But the LTU doesn't even open now, so I can't use it for import.
TsahiReznik2979
Message 6 of 18 (2,133 Views)
06-18-2013 11:52 PM in reply to: ankushved
This is instructions how to use LTU, when it does open.
Not helpful, but thanks.
TsahiReznik2979
Message 7 of 18 (2,133 Views)
06-18-2013 11:54 PM in reply to: TravisNave
Thanks T
I read in many placed the LTU hardly ever works.
I tried your online activation method, asking for a new activation code.
Waiting to hear from Autodesk on that.
but where do I place that?
Do I need to uninstall and install again?
I mean, when I try to open the installed Maya there's no activation option,
it just tells me there's no license.
Member
ankushvedautodesk
Message 8 of 18 (2,124 Views)
06-19-2013 12:23 AM in reply to: TsahiReznik2979
What is the command or steps you are following for launching LTU? Can you attach some screenshots?
TsahiReznik2979
Message 9 of 18 (2,122 Views)
06-19-2013 12:53 AM in reply to: ankushvedautodesk
I just go to the start menu,
and press the icon:
License Transfer Utility - Maya 2014
Member
ankushvedautodesk
Message 10 of 18 (2,117 Views)
06-19-2013 01:13 AM in reply to: TsahiReznik2979
Try this:
Open Terminal and type in the following command and then run Enter
/Applications/Autodesk/Adlm/R7/LTU.app/Contents/MacOS/LTU 657F1 2014.0.0.F -d "SA"
This should open up LTU. Let me know the outcome.
