Hello dear Community i alrdy posted a thread but apparently there is nobody answering so im trying my luck again^^
I succesfully installed it on my Laptop which runs Windows 7 but on my tower which runs Vista it doesnt seem to work. I already did the thing where u delete ur Redistributables but it did not help. I hope you can find a solution.
This is my installation Log :
2014/4/11:13:23:58 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:23:58 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:23:58 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:23:58 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:23:58 Armée Tricolores ARMÉETRICOLO-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-46532129 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/11:13:23:58 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI67E9.tmp
2014/4/11:13:24:28 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:24:00 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:24:00 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:24:00 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI67E9.tmp
2014/4/11:13:24:00 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:24:04 Armée Tricolores ARMÉETRICOLO-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:24:27 Armée Tricolores ARMÉETRICOLO-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:24:28 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:13:26:07 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:13:26:07 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:13:26:07 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:13:26:16 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:13:26:16 Armée Tricolores ARMÉETRICOLO-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:26:20 Armée Tricolores ARMÉETRICOLO-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:26:20 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:13:26:44 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:13:26:44 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:13:27:01 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:28:52 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:28:52 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:28:52 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:28:52 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:28:52 Armée Tricolores ARMÉETRICOLO-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-46532129 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/11:13:28:52 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE3EB.tmp
2014/4/11:13:28:56 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:28:53 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:28:53 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:28:53 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE3EB.tmp
2014/4/11:13:28:53 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:28:55 Armée Tricolores ARMÉETRICOLO-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:28:55 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:13:29:00 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:13:29:00 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:13:29:00 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:13:29:03 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:13:29:03 Armée Tricolores ARMÉETRICOLO-PC Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:29:03 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:13:29:23 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:13:29:23 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:13:29:50 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:38:10 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:38:10 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:38:10 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:38:10 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:38:10 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:13:38:10 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI66A2.tmp
2014/4/11:13:38:18 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:38:13 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:38:13 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:38:13 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI66A2.tmp
2014/4/11:13:38:13 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:38:22 Armée Tricolores ARMÉETRICOLO-PC [Error: 1056] Es wird bereits eine Instanz des Dienstes ausgeführt.
2014/4/11:13:38:22 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:40:02 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:40:02 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:40:02 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI1612.tmp
2014/4/11:13:40:02 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:40:05 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:43:04 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:43:04 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:43:04 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:43:04 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:43:04 Armée Tricolores ARMÉETRICOLO-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-46532129 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/11:13:43:04 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE3DC.tmp
2014/4/11:13:43:26 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:43:06 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:43:06 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:43:06 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE3DC.tmp
2014/4/11:13:43:06 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:43:08 Armée Tricolores ARMÉETRICOLO-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:43:26 Armée Tricolores ARMÉETRICOLO-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:43:27 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:13:43:30 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:13:43:30 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:13:43:39 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:13:43:39 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:13:43:45 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:13:43:45 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:13:43:45 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:13:44:03 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:13:44:03 Armée Tricolores ARMÉETRICOLO-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:44:07 Armée Tricolores ARMÉETRICOLO-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:44:07 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:13:44:26 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:13:44:27 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:13:45:26 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:49:20 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:49:20 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:49:20 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9D5B.tmp
2014/4/11:13:49:20 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:49:24 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:13:49:19 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:49:19 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:13:49:19 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:49:19 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:13:49:19 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:13:49:19 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9D5B.tmp
2014/4/11:14:40:08 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:40:08 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:14:40:08 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:14:40:08 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:14:40:08 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:14:40:08 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI23E9.tmp
2014/4/11:14:40:29 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:14:40:13 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:40:13 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:14:40:13 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI23E9.tmp
2014/4/11:14:40:13 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:14:40:22 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:14:40:29 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:14:40:33 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:14:42:04 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:14:42:12 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:14:42:12 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:14:42:29 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:14:57:01 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:57:01 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:14:57:01 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:14:57:01 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:14:57:01 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:14:57:01 Armée Tricolores ARMÉETRICOLO-PC An instance of setup is already running. Only one instance of setup can run at a time.2014/4/11:14:57:03 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:14:42:30 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:14:57:05 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:14:57:08 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:57:08 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:14:57:08 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:14:57:08 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:14:57:08 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:14:57:08 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIB243.tmp
2014/4/11:14:57:17 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:14:57:11 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:57:11 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:14:57:11 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIB243.tmp
2014/4/11:14:57:11 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:14:57:14 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:14:57:17 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:14:57:30 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:24:00 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:24:00 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:24:00 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI3E7B.tmp
2014/4/11:15:24:00 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:24:03 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:15:24:04 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:15:23:56 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:23:56 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:23:56 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:23:56 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:23:56 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:15:23:56 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI3E7B.tmp
2014/4/11:15:24:06 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:24:06 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:15:24:52 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:15:24:55 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:15:24:55 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:25:15 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:15:25:16 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:15:31:05 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:31:59 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:31:59 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:31:59 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:31:59 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:31:59 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:15:31:59 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9D2E.tmp
2014/4/11:15:32:03 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:32:01 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:32:01 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:32:01 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9D2E.tmp
2014/4/11:15:32:01 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:32:03 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:15:32:04 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:15:32:06 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:15:32:32 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:15:32:34 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:15:32:34 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:33:00 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:15:33:01 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:15:33:04 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:34:41 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:34:41 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:34:41 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:34:41 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:34:41 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:15:34:41 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI1578.tmp
2014/4/11:15:34:45 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:34:42 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:34:42 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:34:42 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI1578.tmp
2014/4/11:15:34:42 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:34:44 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:15:34:45 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:15:34:48 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:15:35:23 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:15:35:25 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:15:35:25 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:35:48 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:15:35:49 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:15:38:17 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:40:43 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:40:43 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:40:43 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:40:43 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:40:43 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:15:40:43 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9C44.tmp
2014/4/11:15:40:51 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:40:47 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:40:47 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:40:47 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9C44.tmp
2014/4/11:15:40:47 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:40:51 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:15:40:52 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:15:40:54 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:15:42:02 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:15:42:03 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:15:42:03 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:15:42:34 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/11:15:42:34 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:43:01 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:15:43:02 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:15:43:55 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:44:44 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:44:44 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:44:44 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:44:44 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:44:44 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:15:44:44 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI4742.tmp
2014/4/11:15:44:48 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:15:44:45 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:44:45 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:15:44:45 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI4742.tmp
2014/4/11:15:44:45 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:15:44:48 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:15:44:49 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:15:44:51 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:15:45:18 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:15:45:19 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:15:45:19 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:15:45:48 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/11:15:45:48 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:46:13 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:15:46:14 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:15:46:34 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:17:28:58 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:28:58 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:17:28:58 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:17:28:58 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:17:28:58 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:17:28:58 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIB6C8.tmp
2014/4/11:17:29:01 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:17:28:59 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:28:59 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:17:28:59 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIB6C8.tmp
2014/4/11:17:28:59 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:17:29:01 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:17:29:03 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:17:29:05 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:17:29:41 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:17:29:43 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:17:29:43 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:17:30:12 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/11:17:30:12 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/4/11:17:30:37 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/4/11:17:30:37 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/4/11:17:30:49 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/4/11:17:30:49 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:17:31:18 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:17:31:18 Armée Tricolores ARMÉETRICOLO-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/11:17:31:20 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:17:31:28 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:17:39:30 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:39:30 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:17:39:30 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:17:39:30 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:17:39:30 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:17:39:30 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI5A57.tmp
2014/4/11:17:39:36 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:17:39:31 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:39:31 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:17:39:31 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI5A57.tmp
2014/4/11:17:39:31 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:17:39:36 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:17:39:37 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:17:39:39 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:17:39:55 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:17:39:56 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:17:39:56 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:17:40:28 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/11:17:40:28 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/4/11:17:40:52 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/4/11:17:40:52 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:17:41:20 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:17:41:21 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:17:41:56 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:17:43:41 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:43:41 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:17:43:41 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:17:43:41 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:17:43:41 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:17:43:41 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI31C1.tmp
2014/4/11:17:43:51 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:17:43:47 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:43:47 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:17:43:47 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI31C1.tmp
2014/4/11:17:43:47 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:17:43:50 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:17:43:51 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:17:43:53 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:17:44:06 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:17:44:07 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:17:44:07 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:17:44:54 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/11:17:44:54 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/4/11:17:45:17 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/4/11:17:45:17 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/4/11:17:45:29 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/4/11:17:45:29 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:17:46:00 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:17:46:00 Armée Tricolores ARMÉETRICOLO-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/11:17:46:02 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:17:48:30 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:20:08:30 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:20:08:30 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:20:08:30 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:20:08:30 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:20:08:30 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/11:20:08:30 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIC76E.tmp
2014/4/11:20:08:37 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/11:20:08:31 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:20:08:31 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/11:20:08:31 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIC76E.tmp
2014/4/11:20:08:31 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/11:20:08:36 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/11:20:08:51 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/11:20:08:55 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/11:20:09:10 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/11:20:09:13 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/11:20:09:13 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:20:10:08 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/11:20:10:08 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:20:10:37 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/11:20:10:38 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/11:20:12:33 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/12:12:53:51 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/12:12:53:51 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/12:12:53:51 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/12:12:53:51 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/12:12:53:51 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/12:12:53:51 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE771.tmp
2014/4/12:12:54:08 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/12:12:53:56 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/12:12:53:56 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/12:12:53:56 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE771.tmp
2014/4/12:12:53:56 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/12:12:54:07 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/12:12:54:10 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/12:12:54:13 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/12:12:54:38 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/12:12:54:40 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/12:12:54:40 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/12:12:55:14 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/12:12:55:15 Armée Tricolores ARMÉETRICOLO-PC PageOpen InstallCompleteDialog
2014/4/12:12:55:19 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/12:13:09:38 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/12:13:09:38 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/12:13:09:38 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/12:13:09:38 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/12:13:09:38 Armée Tricolores ARMÉETRICOLO-PC CommandLine
2014/4/12:13:09:38 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI57E0.tmp
2014/4/12:13:09:41 Armée Tricolores ARMÉETRICOLO-PC === Setup ended ===
2014/4/12:13:09:39 Armée Tricolores ARMÉETRICOLO-PC === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/12:13:09:39 Armée Tricolores ARMÉETRICOLO-PC Path_Length: 151
2014/4/12:13:09:39 Armée Tricolores ARMÉETRICOLO-PC Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI57E0.tmp
2014/4/12:13:09:39 Armée Tricolores ARMÉETRICOLO-PC Launch
2014/4/12:13:09:41 Armée Tricolores ARMÉETRICOLO-PC PageOpen LaunchDialog
2014/4/12:13:09:43 Armée Tricolores ARMÉETRICOLO-PC PageOpen LicenseDialog
2014/4/12:13:09:45 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductInfoDialog
2014/4/12:13:10:05 Armée Tricolores ARMÉETRICOLO-PC PageOpen ProductSelectionDialog2
2014/4/12:13:10:06 Armée Tricolores ARMÉETRICOLO-PC PageOpen FullProgressDialog
2014/4/12:13:10:06 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/12:13:10:35 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/12:13:10:35 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/4/12:13:10:56 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/4/12:13:10:56 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/4/12:13:11:08 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/4/12:13:11:08 Armée Tricolores ARMÉETRICOLO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/12:13:11:34 Armée Tricolores ARMÉETRICOLO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/12:13:11:34 Armée Tricolores ARMÉETRICOLO-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Thanks a lot for ur help i really need it !
