Installation & Licensing
Maya 2014 - error 2
5 REPLIES 5
joao_nunes_autodesk
1410 Views, 5 Replies
Maya 2014 - error 2
Hi.
Every time I try to activate my student version of Maya 2014 I get this error: The serial number you entered is not valid. Try again. (Error 2). However I'm quite sure that the serial number is right: I'm copying and pasting the number!
Can you please help me?
João
Tags (2)
5 REPLIES 5
Hello Joao,
Please do the following:
1) Delete the adskflex_*_tsf.data file located here:
Vista/Windows 7
C:\ProgramData\FLEXnet\adskflex_*_tsf.data
(Note this file is hidden so you may need to enable show hidden files under folder options)
2) Then Re-open Maya and it will prompt you for a manual activation, please contact us via phone at 1-800-551-1490 to obtain a new activation code over the phone.
Byron M.
Also, there have been reports that copy/paste causes a failure issue on serial numbers, whereas just simply typing it in correctly works.  Just a thought.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thanks for your reply!
Since I'm using Maya on Mac Osx, and not Windows, can you please tell what
to do? And is there a way to avoid phone calls? Only because it is not so
cheap to call to US from Portugal...
Thanks!
Jo?o.
Follow the steps below to Reset the Standalone licensing on your MAC OS:
http://upandready.typepad.com/up_and_ready/2013/02/reset-standalone-licensing-on-the-mac.html
Byron M.
THANK YOU!
It worked fine!
Best regards,
Jo?o Nunes
Administrator Productivity
