Installation & Licensing
Maya 2013 language
5 REPLIES 5
10526 Views, 5 Replies
Maya 2013 language
I've downloaded english Maya 2013 but after I've installed it and ran it, it is in Chinese instead.
I've tried re-installing several times and it iremained in Chinese language.
May I know how to change the language of my Maya 2013 programme?
5 REPLIES 5
TravisNave
Did you download this legally from Autodesk?  And is your Windows a Chinese version?
Autodesk Forums:
in reply to: TravisNave
Yes, I believe I did. I'm a student and registered under student/educator to download it for non-commercial use.
My windows is in English as well.
*Also, when downloading there was only 1 option for language: English. So it baffles me even further because, Chinese was not in the list in the first place and I've no idea how it got there.
*Also, I tried using the "Install now" option but a "Communication Failure" message keep appearing. So, I used the "download" option to install instead and that led to the problem I'm facing right now (Language).
philip.s
Hi Calvin,
The Maya 2013 download / installer contains the English, Japanese, and Chinese language options.
Check out this Maya Online Help solution for a potential language switch, specifically by changing the MAYA_UI_LANGUAGE Environment Variable to en_US, in your system properties / advanced system settings.
Please let us know if this works out / accept as a solution if this fully resolves the issue.
in reply to: philip.s
Hi Philip,
It worked! Thanks a lot :D.
Administrator Productivity
