Installation & Licensing
Member
xenon373
Message 1 of 6 (4,826 Views)
[Maya 2013] All Products Failed to Install
4826 Views, 5 Replies
10-16-2012 11:59 AM
Hello
I have a problem since I want to install Maya 2013, but I can't. I've tried several times now and I have not been able to find a solution on the internet.
I tell the installer to install everything and then it begins installing. A few seconds after I see the Maya Logo, I get a weird box with information about console commands for Windows. I press OK and a few seconds after, the installer exits and tells me all 5 products failed to install.
I am running Windows 7 64 Bit Home Edition. I am installing the Educational Version of Autodesk Maya 2013.
The log:
2012/10/16:20:54:19 Vipar VIPAR-PC === Setup started on VIPAR-PC by Vipar ===
2012/10/16:20:54:19 Vipar VIPAR-PC Launch
2012/10/16:20:54:23 Vipar VIPAR-PC === Setup ended ===
2012/10/16:20:54:20 Vipar VIPAR-PC === Setup started on VIPAR-PC by Vipar ===
2012/10/16:20:54:20 Vipar VIPAR-PC Launch
2012/10/16:20:54:23 Vipar VIPAR-PC PageOpen LaunchDialog
2012/10/16:20:54:40 Vipar VIPAR-PC PageOpen LicenseDialog
2012/10/16:20:54:44 Vipar VIPAR-PC PageOpen ProductInfoDialog
2012/10/16:20:56:31 Vipar VIPAR-PC PageOpen ProductSelectionDialog2
2012/10/16:20:56:35 Vipar VIPAR-PC PageOpen FullProgressDialog
2012/10/16:20:56:35 Vipar VIPAR-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): C:\Autodesk\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Vipar\AppData\Local\Temp;C:\Program Files\Java\jre7\bin;C:\Program Files\Java\jre7\bin;\vcredist_x64_2005.log"" "
2012/10/16:20:56:52 Vipar VIPAR-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
Member
xenon373
Message 2 of 6 (4,812 Views)
So I went into the Installation folders and manually inst...
10-16-2012 01:18 PM in reply to: xenon373
So I went into the Installation folders and manually installed the Redistributable that it kept stopping at, and the installer at least progress further now.
Member
xenon373
Message 3 of 6 (4,804 Views)
Re: So I went into the Installation folders and manually inst...
10-16-2012 01:40 PM in reply to: xenon373
Yeah it works now.
New Member
u0700596
Message 4 of 6 (4,750 Views)
Re: [Maya 2013] All Products Failed to Install
10-23-2012 02:44 PM in reply to: xenon373
Hey I am having the same issue! How did you manually install redistribute?
Member
xenon373
Message 5 of 6 (4,748 Views)
10-23-2012 02:47 PM in reply to: u0700596
If you get all the installation files from either of the download options, some of the folders holds the redistributions of the programs. I simply went into those installation files and found the x64 and x86 folders. Then I just tried installing (some failed as they were already installed) and then I could install Maya 2013.
New Member
megagigala4
Message 6 of 6 (1,557 Views)
12-25-2013 05:11 AM in reply to: xenon373
Hey guys, i have the same problem and if i install these x64/x86 files there comes another problem o___O
