Installation & Licensing
New Member
ChristianScheffold
Message 1 of 14 (13,264 Views)
Maya 2013 (657E1 2013.0.0.F), error 20 ,Please help
13264 Views, 13 Replies
04-20-2012 11:43 AM
I am having a strange problem in running Maya.
When I am trying to activate May 2013 I am getting the following message:
License was not obtained
Tried Maya 2012 (657E1 2013.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='657e1'
License file override:
environment variable MAYA_ALT_EN is not set
Hello Philip,
                 Thank you for your reply my problem is solved by deleting the folder name is FLEXnet. Located in C:\ProgramData.
                 I also done some things in my pc by seeing this http://www.youtube.com/watch?v=ZiLwrQb3hnU video on youtube but i don't know that this video helped me or not after that i just deleted FLEXnet folder by seeing some forms.
But after all this i am happy my problem is solved. :smileyhappy:
                 I attached the screenshot that maya successfully running in my pc without any problem.
                 Thank you for your support.
TravisNave
Message 2 of 14 (13,262 Views)
Re: Student Version Maya 2013 (657D1 2013.0.0.F), error 20 ,Please help
04-20-2012 11:53 AM in reply to: ChristianScheffold
BTW, your product key for 2013 should be 657E1.  Are you using the correct serial number too?
Here let me Google that for you:
http://lmgtfy.com/?q=site:autodesk.com+MAYA_ALT_EN+is+not+set
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
New Member
ChristianScheffold
Message 3 of 14 (13,255 Views)
04-20-2012 12:03 PM in reply to: TravisNave
It is  657E1!
TravisNave
Message 4 of 14 (13,244 Views)
04-20-2012 01:00 PM in reply to: ChristianScheffold
Wel, before you edited the post, you originally had 657D1.  I just wanted to make sure that was correct for 2013.
New Member
christian.strain
Message 5 of 14 (11,166 Views)
Re: Maya 2013 (657E1 2013.0.0.F), error 20 ,Please help
10-30-2012 09:50 AM in reply to: ChristianScheffold
I'm having this same issue.  Here is the error:
Tried Maya 2013 (657E1 2013.0.0.F), error 20
License method:
Product choice:
I just updated my GeForce cards drivers, could that have something to do with it?  Is there an update I can use for Maya?
New Member
s.parsons
Message 6 of 14 (9,488 Views)
02-15-2013 08:36 AM in reply to: ChristianScheffold
I'm having the exact same problem, has anyone figured this out yet?
New Member
mmosher
Message 7 of 14 (8,598 Views)
03-21-2013 10:59 PM in reply to: s.parsons
Same issue.  Infact, not a single Autodesk application (Alias, Mudbox, Sketchbook...) will launch on OSX 10.8.3
Way to do guys, you're dev team is great...
New Member
rpatil1592
Message 8 of 14 (7,125 Views)
06-15-2013 08:41 PM in reply to: ChristianScheffold
I downloaded student version of Maya 2013 64-bit and getting same problem.1st time i saw the activation screen but after that getting this issue :smileyindifferent:   please help.
philip.s
Message 9 of 14 (7,083 Views)
06-17-2013 02:05 PM in reply to: rpatil1592
Hello Rahul,
Looking through the Discussion Forums, I was able to find a couple of relevant threads that might be a good starting point.
http://forums.autodesk.com/t5/Installation-Licensing/License-issue-Error-20-on-Windows-7-Maya-2011/t...
http://forums.autodesk.com/t5/Installation-Licensing/ERROR-20-WHATS-UP/m-p/3193202
Specifically,
As Licensing is almost the same for most Autodesk products.
http://area.autodesk.com/forum/autodesk-3ds-max/installation---hardware---os/the-software-license-ch...
You can also try to add license service exe(C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService64.exe) to DEP exceptions (http://www.online-tech-tips.com/windows-xp/disable-turn-off-dep-windows/)
Close the application, then delete the casecadeinfo.cas file located in the following directory and try running again:
Windows 7:
C:\ProgramData\Autodesk\AdLM\
Windows XP:
C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM\
Another user posted that a system restore resolved their issue.
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
Philip Schmelzer
New Member
rpatil1592
Message 10 of 14 (6,203 Views)
08-01-2013 07:36 PM in reply to: philip.s
Hello Philip,
