Installation & Licensing
Maya 2013 (657E1 2013.0.0.F), error 20 ,Please help
13 REPLIES 13
Message 1 of 14
ChristianScheffold
19091 Views, 13 Replies
I am having a strange problem in running Maya.
When I am trying to activate May 2013 I am getting the following message:
License was not obtained
Tried Maya 2012 (657E1 2013.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='657e1'
License file override:
environment variable MAYA_ALT_EN is not set
13 REPLIES 13
Message 2 of 14
BTW, your product key for 2013 should be 657E1.  Are you using the correct serial number too?
Here let me Google that for you:
http://lmgtfy.com/?q=site:autodesk.com+MAYA_ALT_EN+is+not+set
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
Autodesk Forums:
Message 3 of 14
It is  657E1!
Message 4 of 14
Wel, before you edited the post, you originally had 657D1.  I just wanted to make sure that was correct for 2013.
Autodesk Forums:
Message 5 of 14
I'm having this same issue.  Here is the error:
Tried Maya 2013 (657E1 2013.0.0.F), error 20
License method:
Product choice:
I just updated my GeForce cards drivers, could that have something to do with it?  Is there an update I can use for Maya?
Message 6 of 14
I'm having the exact same problem, has anyone figured this out yet?
Message 7 of 14
mmosher
in reply to: s.parsons
Same issue.  Infact, not a single Autodesk application (Alias, Mudbox, Sketchbook...) will launch on OSX 10.8.3
Way to do guys, you're dev team is great...
Message 8 of 14
I downloaded student version of Maya 2013 64-bit and getting same problem.1st time i saw the activation screen but after that getting this issue Smiley Indifferent   please help.
Message 9 of 14
philip.s
in reply to: rpatil1592
Hello Rahul,
Looking through the Discussion Forums, I was able to find a couple of relevant threads that might be a good starting point.
http://forums.autodesk.com/t5/Installation-Licensing/License-issue-Error-20-on-Windows-7-Maya-2011/t...
http://forums.autodesk.com/t5/Installation-Licensing/ERROR-20-WHATS-UP/m-p/3193202
Specifically,
As Licensing is almost the same for most Autodesk products.
http://area.autodesk.com/forum/autodesk-3ds-max/installation---hardware---os/the-software-license-ch...
You can also try to add license service exe(C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService64.exe) to DEP exceptions (http://www.online-tech-tips.com/windows-xp/disable-turn-off-dep-windows/)
Close the application, then delete the casecadeinfo.cas file located in the following directory and try running again:
Windows 7:
C:\ProgramData\Autodesk\AdLM\
Windows XP:
C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM\
Another user posted that a system restore resolved their issue.
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
Message 10 of 14
rpatil1592
in reply to: philip.s
Hello Philip,
                 Thank you for your reply my problem is solved by deleting the folder name is FLEXnet. Located in C:\ProgramData.
                 I also done some things in my pc by seeing this http://www.youtube.com/watch?v=ZiLwrQb3hnU video on youtube but i don't know that this video helped me or not after that i just deleted FLEXnet folder by seeing some forms.
But after all this i am happy my problem is solved. Smiley Happy
                 I attached the screenshot that maya successfully running in my pc without any problem.
                 Thank you for your support.
Message 11 of 14
philip.s
Happy to hear and you're most very welcome Rahul!
Message 12 of 14
j-mantel
Hello, I've got the same problem and now tried to start the FLEXnet, but I receive the message: "Error3: System can't find path".  Does anybody know how to solve this?
Message 13 of 14
jarrettgreene82
My issue is the same but it's on Mac 10.8.5.  Is there an fix?
License method:
Product choice:
environment variable MAYA_LICENSE='unlimited'
Message 14 of 14
higoing00
in reply to: TravisNave
Weird, is it always supposed to be e1 because on mine I have F1? And used the CORRECT Serial number.
Administrator Productivity
