Installation & Licensing
Maya 2012 refuses to open files
6 REPLIES 6
537 Views, 6 Replies
I've got 64bit Maya installed on my 64bit Windows 7 computer, it installed perfectly and the key and such were handled fine.
I set up my sketches and went about making my model.
During a time where our internet modem died I decided to be productive and do some more of my 3D work. Unfortunately when I got to a point where I had done enough to warrant a save Maya froze. I say froze as in it locked up and would not let me click anything inside that window yet my task manager reckonised it as still running.
I retried Maya - it started perfectly and seemed functional but as soon as I clicked "Open File" it decided to lock up again. Struck by that I decided to launch Maya by way of my save file which it loaded perfectly but as soon as I tried to do anything to the save decided to lock up.
At this point I thought it was because I had no internet and the license couldn't check but as soon as we had a new modem I still continue to have this problem.
I have reinstalled the product to no avail.
If there is anyone out there who has any insight on this it would be much appreciated.
6 REPLIES 6
TravisNave
Have you tried logging on with a different user to see if it works under another profile?  The hardware failure could have corrupted additional system files.  In some instances it can cause licensing issues.  A repair install might be a good option for you.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
My profile is the only one on my computer as it is a personal laptop.
I have repair installed as well as fully uninstalled then reinstalled Maya to no avail.
TravisNave
Create a new user in Control Panel > Users with local admin rights and login as that user.
Autodesk Forums:
I activated the Guest account and logged into that.
Maya does work in that profile.
TravisNave
That's what I figured.  Your Windows profile has some sort of corrupted file that is preventing the product from working properly.  The easiest thing to do is just create a new profile.
http://windows.microsoft.com/en-US/windows-vista/fix-a-corrupted-user-profile
Autodesk Forums:
Thank you for the help 😃
I will get onto that as soon as I can.
Administrator Productivity
