I have to install Maya for one of my classes and the professor said to use either the 2012 or 2013 edition. When installing either one everything goes smoothly up until it starts to actually install. When it runs the install for the MS C++ 2005 part of the installation it goes for a few minutes then everything ends. I am told that the installation was successful but that some components failed to install, maya itself being one of the things that did not install. It does not pop up any error message during this process but when I check the installation log file, it says the same thing for both the 2012 and the 2013 versions ( I tried both in case there was some error with one over the other). It says this every time in the log file
2015/1/17:12:34:41 Brian BRIAN-PC === Setup started on BRIAN-PC by Brian ===
2015/1/17:12:34:41 Brian BRIAN-PC Launch
2015/1/17:12:35:09 Brian BRIAN-PC === Setup ended ===
2015/1/17:12:34:52 Brian BRIAN-PC === Setup started on BRIAN-PC by Brian ===
2015/1/17:12:34:52 Brian BRIAN-PC Launch
2015/1/17:12:35:09 Brian BRIAN-PC PageOpen LaunchDialog
2015/1/17:12:35:13 Brian BRIAN-PC PageOpen LicenseDialog
2015/1/17:12:35:15 Brian BRIAN-PC PageOpen ProductInfoDialog
2015/1/17:12:38:14 Brian BRIAN-PC PageOpen ProductSelectionDialog2
2015/1/17:12:40:35 Brian BRIAN-PC PageOpen FullProgressDialog
2015/1/17:12:40:36 Brian BRIAN-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): C:\Autodesk\Maya_2013_CEJ_Win_64-bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Brian\AppData\Local\Temp\vcredist_x64_2005.log"" "
2015/1/17:12:41:29 Brian BRIAN-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
I have searched for the 1603 error and tried all of the things I could find that people found worked for them atm save for uninstalling every redistributable I have in one go instead of just the 2005 redistributable so far, can anyone help me find out what is causing this error?
