Most likely the cause of this error is corrupted License.env file, which is located:
Windows:
For Maya 2010 - C:\Program Files\Autodesk\Maya2010\bin\License.env
For Maya 2011 - C:\Program Files\Autodesk\Maya2010\bin\License.env
Linux:
/usr/autodesk/maya2010-x64/bin/License.env
/usr/autodesk/maya2011-x64/bin/License.env
Mac:
/Applications/Autodesk/maya2011/Maya.app/Contents/License.env
/Applications/Autodesk/maya2010/Maya.app/Contents/License.env
Sample content for Trial and Standalone:
MAYA_LICENSE=unlimited
MAYA_LICENSE_METHOD=standalone
Sample content for Network:
MAYA_LICENSE_METHOD=network
Douglas Lauritsen, Autodesk Product Support
We appreciate your quick feedback on this forum!
I have the same error. But I don't have a folder maya 2010.
In the license.env:
MAYA_LICENSE_METHOD=network.
But I have a folder Flexlm.
What can I try?
Is it that there is a period (.) at the end of the line for:
If it is like this the period will cause trouble:
If so remove the period and you should be good.
I tried editing the license env. But when i tried saving it a message popped out " access denied"...?
guess deleting the period doesn't work
By default the License.env file is in the “C:\Program Files” folder. You will need Modify privileges to edit anything that is contained therein. An Administrator may need to perform this edit for you.
Your username or group could be added to the security settings for either “C:\Program Files” or “C:\Program Files\Autodesk\Maya20**” with Modify privileges. Depending on the security policies Modify privileges for “C:\Program Files” may not be allowed. Using “C:\Program Files\Autodesk\Maya20**” is a good alternative as it retains security for “C:\Program Files” while providing access to the Maya folder where there are files you may need to want to edit.
Just wanted to confirm that the problem might be related to the license override.
The license env. works fine.
I just can't see how to fix the override.
"License file override:
environment variable MAYA_ALT_EN is not set"
so how do you set it?
thanks for the update.
Can you upload your License.env file to this thread?
sorry it doesn't have a valid extension according to this site
Rename the extension to .txt, then post the .txt. I’ll request that the Administrators of the forum add the .env as an accepted extension.
hey cool!
if you notice, license file override is not mentioned in the text.
OK sorry about that, all looks OK in the .env file. Are there other error messages associated with this? Is there a .log file in this folder “C:\ProgramData\Autodesk\Adlm?” If so can you upload it? Had Maya been working previously?
Uninstall and reinstall. To prevent some external factor from interrupting something perform the reinstall from Diagnostic Mode.
I am having this exact same problem. I have installed from the Maya Hotfix 2 download. With Composite I get prompted with the activation screen, with Maya I get nothin apart from this.
License was not obtained
License method:
can't determine license method
Product choice:
can't determine product choice
environement variable MAYA_ALT_EN is not set.
Please can someone from autodesk advise on how this can be fixed. I see the dates of some of these posts are weeks+ old and there is no solution?
If i start Maya from a command prompt, first setting the envioronment variables manually that are in the Maya\bin\License.env file I still get this error, although it has the method and product choice set, it still says License was not obtained.
Where should I be looking to correct this. Why is maya not pulling the license method and product choice from the License.env file ?
I have also tried restarting the Flexnet services, which were not started after I first installed ?
Please note I do not have a . at the end of anything in my License.env, I have started in Diagnostic mode on Windows 7 Ultimate, and installed with only the Flexnet services and the Windows installer service started. same problem. I have also restarted, reinstalled many times to try to get this to work.
Just incase anyone else has these problems. I now have mine working. The problem stemmed from having Maya 2009 already installed. MAYA_LOCATION environment variable was set to that of 2009. It was looking at the env vars in C:\program files\Autodesk\Maya2009\bin\License.env for the MAYA_LICENSE and MAYA_LICENSE_METHOD which is empty.
check the adlm log file in c:\Flexlm\ and you will see the path of 2009 mentioned
setting MAYA_LOCATION to my "C:\Program Files\Autodesk\Maya2011" fixes my problem. will possibly break 2009, but can run via a .bat that sets this var on startup perhaps.
Problem solved
Ok here is what I did
Go to Control panel on your computer
find system icon and activated it
go to advance and Environment Variables
scroll down to maya-location
tast edit
and the new variable value is
C:\Autodesk\maya2011
or what ever location your Maya 2011 is on.
hope this will help some.
kent
