Hey everyone,
I was hoping that someone could help me get up and running with maya 2011. I’m an art student, and I downloaded Maya 2011 off the Autodesk website for use with school work in the fall, however, I’m having some issues. It installed fine (so far as I know, anyway), but when I try to open the program, I get the following message:
License was not obtained
Tried Maya 2011 (657C1 2011.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD=’standalone’
Product choice:
environment variable MAYA_LICENSE=’unlimited’
License file override:
environment variable MAYA_ALT_EN is not set
I’ve searched high and low for an answer, but I haven’t come across one yet, despite two days of searching. I’m hoping someone here can help me with the solution. In case anyone has any idea what’s going on here, I’ll list my computer’s software and hardware specifications, etc.
MacBook Pro, mid-2009 unibody, 2.53 GHz intel core 2 duo, 4 gigs of ram, 256mb NVidia GeForce 9400M graphics card.
Currently, I am running OSX Snow Leopard, version 10.6.4, on a recently replaced 320 gig hard drive (fresh from apple yesterday).
I also have the serial number and activation codes for Maya, and as far as I know, I installed it all properly, which is why I’m stumped. A HUGE thanks in advance to anyone who can provide any help at all (even if it’s not much in your eyes, it’ll make a world of difference to me).
Also, as I’m a new member, I apologize if this has been discussed before, however I did a search and nothing came up for me. Additionally, I’ve read the user installation manual (it bears no specific mention of this problem/error) and I’ve scoured the Autodesk website to no avail. Seeing as all of these labours have fallen short of the mark, this post is as much a plea as a question, if you get my meaning!
Solved by david.lau. Go to Solution.
You will need to delete folders highlighted (attached) and remove Maya 2011 folder and then re-install the Maya.
Done as you wrote, but the error still shows. Can't run Maya. Found those folders (see attachment), deleted them, deleted the Maya folder (tried also with deleting the whole Autodesk folder in applications) and reinstalled Maya with 000-00000000 serial and it still didn't run. Of course afer reinstallation those folders are there again (in Application support and Preferences folders).
I don't know if it matters but during the installation there is a "Installation failed on exit" comment. Is it normal? I thought that maybe I downloaded something wrong but after trying to download Maya 2011 installer few times this comment shows everytime during installation. The installation of course finishes and I can click Done to finish it, but then the program starts with the error mentioned earlier.
Try this set english language on your system, i had the same problem and it helped, when i changed from croatian to english on Mac OSX 10.6.4.
We moved your post to a new topic.
hi i 've got the same problem for installing maya i want to know how did u solve it? how did u chang the language? from where and how does it work?!
I can't really call that a solution, to be honest.
It's a bypass, bypassing should be temporary, You should make an update that would fix this.
Sorry, but this is very inconvenient solution. The main language of my MacOS is Russian. So, always switching to English language just for running just a one specific program like a Maya it is very inconvenient and inefficient!
Have you fix this problem by some update?
The same question as above. Are the any chances that Maya will work on Mac OS X with any other than english localization?
hello i am having the same issue on my machine but im on a pc running windows 7 only a few days ago i was working on my programs but it seems aall of a sudden im getting the same error one all of my autodesk sorftwair.
max 2011 64
mudbox 2011 64
spftimage 2011 64
i dont understand how this has happend as nothing has changed the only thing i can think has chnged is the enternet when down the other day at the uni as i live in halls of residance and the internet is supplied by the university.
since then they have the internet back up and possibly my ip could have changed is that possibly the case. im lost without these programs as im currently studying my final year and need them for my dissertation. could you pleas help me out here as im in desperat need of a fast solution.
its the same error message ''error 20 '' and its on the loade up of any of the programs
any help right now would be massivly appriciated as i need this to be quick.
thanx for your time
nicholas uttley
ip change will not break license.
did you try the suggestions in the thread (deleting the license files )
ok im not all that up on computer fiddly bts when it comes to programs. but reading through this person is refering to mac and im running a pc. is there a diffrance in what im ment to do ? .
also there is alot of diffrent things happening on this issue with this other person is there any chance u could give me a run down on the steps i should take im running windows 7 and my aplication for max is 64 bit.
HI all,
I have been battling with this for over 8 hrs now and my college finally fixed it for me here is how he did.
Edit your maya.lic file located /var/flexlm/
to:
and save this file. *the 2080 is the port number found in your adsk_server.lic (in the same dir)
VENDOR adskflex port=2080
Hope this works for you all - Buying my college lunch.
Unfortunately, "error 20" is still appears!
@COLINKELLY2647 wrote:HI all,
to:
SERVER 127.0.0.1 2080USE_SERVER
This is just a summary on how to hopefully solve this issue for Standalone.
For the ports settings via Network, I would check out this post:
I try to do step-by-step as you advise me.
1. My system is MacOS 10.6.6, language of OS is Russian.
2. I deleted /Library/Application Support/Autodesk/Adlm/
/Library/Preferences/FLEXnet Publisher/FLEXnet/
Also I deleted al of Maya files.
3. I installed Maya 2011 as trial using 000-00000000.
4. I try to run Maya as Trial but get "error 20" again!
If I change my system language to English, Maya run good. But If I change system language to Russian then Maya not run again and "error 20" is appearing.
