I am currently trying to install the 2011 SE of Maya. After I click Install Products from the selection screen, it closes and nothing happens. Setup.exe is in task manager, but nothing is happening. Any ideas? I checked the install log and all it says is install has started, and on the next line, install has closed after I close it out in task manager.
Please try a clean install in Diagnostics mode as true admin
http://usa.autodesk.com/getdoc/id=TS75218
