Everytime I load Maya, the perspective view appears, but the right quarter of the grid and any objects drawn there are cut off from view. Also, an output window appears with the following:
error Fri Oct 22 2010 07:02:39.587000 pid:3436 tid:3504 Save configuration file failed.
error Fri Oct 22 2010 07:02:39.602000 pid:3436 tid:3504 Save configuration file failed.
mental ray for Maya 2010
mental ray: version 3.7.53.5, Jun 17 2009, revision 88216
I'm "Dead in the Water" at this point. Autodesk, please help
I would rename the Prefs folder to "old". This is typically located in:
Documents > maya > 2010 or 2010x64
Then restart Maya.
I have the same problem.
I tried to rename the prefs forlder but it didn't help.
I still get the same message.
I don't know if the error is the cause all my problems, but i gues it is.
