Greetings,
I have Maya 2010 on a Mac running Snow Leopard.
It has worked perfectly for many months; but recently, I get a dialog box with the following message when I try to open the program. How do I fix this?
Thank you.
// Error: file: /Applications/Autodesk/maya2010/Maya.app/Contents/scripts/startup/layerEditor.mel line 4137: Could not find attribute named "defaultRenderLayer.precompTemplate" //
// mental ray for Maya 2010
// mental ray for Maya: using startup file /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/maya.rayrc
// mental ray for Maya: setup
// mental ray for Maya: initialize
// mental ray for Maya: using 1 license
// mental ray for Maya: register extensions
// mental ray Node Factory: loaded
// mental ray for Maya: successfully registered
// mental ray for Maya: loading startup file: /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/maya.rayrc
// parsing /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/include/AdskShaderSDKWrappers.mi
// generating Maya nodes...
// parsing /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/include/architectural.mi
// loading /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/lib/architectural.so
// parsing /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/include/base.mi
// loading /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/lib/base.so
// parsing /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/include/contour.mi
// loading /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/lib/contour.so
// parsing /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/include/paint.mi
// loading /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/lib/paint.so
// parsing /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/include/physics.mi
// loading /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/lib/physics.so
// parsing /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/include/production.mi
// loading /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/lib/production.so
// parsing /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/include/subsurface.mi
// loading /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/lib/subsurface.so
// parsing /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/include/surfaceSampler.mi
// loading /Applications/Autodesk/maya2010/Maya.app/Contents/mentalray/lib/surfaceSampler.so
updateRendererUI;
updateRendererUI;
// Error: file: /Applications/Autodesk/maya2010/Maya.app/Contents/scripts/others/mentalrayUI.mel line 1615: Object not found: mainRenderMenu. //
How do I fix this?
Thank you.
