Installation & Licensing
Maya 2009 uninstall and license transfer
4 REPLIES 4
Veovis
574 Views, 4 Replies
Hello, I own a Maya 2009 stand-alone license.  It is on an older computer that I am going to be getting rid of.  I wish to deactivate the license on that computer, and in the future I may wish to reactivate the license on my new computer.
I have searched and I am unable to find any decent information on the process for this.  Some sources seem to indicate that I need to use a Portable License Utility (PLU) because it is a version year before 2010, but I do not seem to have that utility among the Autodesk files.
My concern is that if I simply uninstall and get rid of the computer, then I will never be able to activate the license again if I choose to.
Short version:  How can I uninstall Maya 2009, and decativate the license, so that I can be able to reinstall and reactivte on another computer in the future when I choose?
Thank you for any help.
4 REPLIES 4
TravisNave
in reply to: Veovis
If you have never upgraded beyond 2009 either manually or on Subscription, you should just install it on your new computer and see if you can activate it.  Note that it is only supported on Windows XP and Vista.  Once you have it working and licensed, then you can remove it from your old machine.  If it will not activate, then you can request a manual activation.
Autodesk Forums:
Veovis
in reply to: TravisNave
Thank you for the quick response.
I was not aware of '09 not being supported beyond Vista.  That is unfortunate, although understandable. I wish I could afford a newer version, but alas...
So from what I gather, you are saying that there is no "deactivation" process for the license?  Just the ordinary software Uninstall?
TravisNave
in reply to: Veovis
That is correct.  That's why I recommend getting it to work first on your new system.  You might be able to get it to work on Windows 7 (or even 😎 but it is simply unsupported.  Doesn't mean that you can't get it to work though.  Just that if it doesn't, you're pretty much out of luck.
Autodesk Forums:
Veovis
Understood.  Thank you again for the information.
Administrator Productivity
