I've installed Max 2011 on my pc running Xp64 but when I clink on the "activate" button I get a blank page with 2 "dots".
I searched on the forum and tried all the proposed solutions but i still cannot activate the software.
I have tried to unregister/register the DLLs, have tried to reset IE8....
Do you have any other solution to try?
Solved by ALESSIOVISINTIN7122. Go to Solution.
Did you try this ?
http://usa.autodesk.com/getdoc/id=TS1053941
OK. Found the solution.
I had to create a new user with administrator access and then authorize Max from the new user account.
That's crazy but worked.
