Installation & Licensing
Max crash on opening - Error loading upiconfig.xml
14 REPLIES 14
Message 1 of 15
4317 Views, 14 Replies
I recently got a blue screen "Bad Pool Header" (win7) error, the system appears to be fine now but ever since Max will not open.  The dump data shows "Error loading upiconfig.xml".  I Did a complete reinstall of Max but that did not fix the problem.  I'm at a loss as to how to approach this.   Attached is the crash data.
Pete
14 REPLIES 14
Message 2 of 15
DarrenP
are you sure the blue screen error is fixed? i wouldn't ignore them
blue screens are usually caused by faulty hardware or a driver problem
http://www.pcworld.com/article/2026248/can-a-bsod-hurt-my-computer-.html
DarrenP
Message 3 of 15
I checked all hardware and no problems were detected. The first reboot after the BSoD things were messed up, my RAM was full though nothing was running.  I shut doiwn, unplugged the system from the wall, rebooted, checked everything and the hardware all seems to be fine.  But for some reason this "upiconfig.xml" file for max is missing?  I cant seem to find any info on this file or how to restore it.  There is also very little info on "Bad Pool Header" BSoD
Message 4 of 15
DarrenP
try running a restore point: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
DarrenP
Message 5 of 15
I un- and reinstalled Max, and am now back to just the same original crash and dumpdata
Message 6 of 15
in reply to: DarrenP
I ran a restore point to a week prior to the problem with no luck.  My reseller thinks the problem may be graphics card related?  I have the most current driver in it.
Message 7 of 15
DarrenP
try changing the graphics mode
start>all programs>autodesk> 3ds Max>change graphics mode
change it to legacy Direct3d
DarrenP
Message 8 of 15
Just tried switching to Legacy3D, did not work.  Right after launch it errors saying "an error ocurred, the aplication will close....."
Thanks for trying, any other suggestions?
Message 9 of 15
It was also suggested I try opening windows in VGA mode to test the graphics cards but Max still failed to launch.
Message 10 of 15
DarrenP
no i have no other suggestions right now
DarrenP
Message 11 of 15
Do you  think I would have better luck if I renewed my subscription and tried to get help that way?
Message 12 of 15
DarrenP
i can't honestly say yes
i think this error is related your graphics card
you can try using an older driver for your graphics card
DarrenP
Message 13 of 15
SOLUTION:  I needed to do a complete clean uninstall and reinstall of 3dsMax and clean out the registry files using these Autodesk instructions:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
All is OK now
Message 14 of 15
try this:
go to you Max's bin directory and rename assemblies to assemblies.ORIG.
that might get you up and operational again... It worked for me!
you'll have some subsequent problems, but I'm working with a rep to sort those out as well.
I will post more if we get to a 100% solution.
THIS DROVE ME BANANAS.
Message 15 of 15
ShreddinPB
I am having this issue, and that link is broken 😞
Administrator Productivity
