This is driving me insane please help I have tried every possible solution on this forum.
2012/9/3:12:20:36 render RENDER1 === Setup started on RENDER1 by render ===
2012/9/3:12:20:36 render RENDER1 Launch
2012/9/3:12:20:46 render RENDER1 === Setup ended ===
2012/9/3:12:20:42 render RENDER1 === Setup started on RENDER1 by render ===
2012/9/3:12:20:42 render RENDER1 Launch
2012/9/3:12:20:47 render RENDER1 PageOpen LaunchDialog
2012/9/3:12:20:49 render RENDER1 PageOpen LicenseDialog
2012/9/3:12:20:52 render RENDER1 PageOpen ProductInfoDialog
2012/9/3:12:21:31 render RENDER1 PageOpen ProductSelectionDialog2
2012/9/3:12:21:36 render RENDER1 PageOpen FullProgressDialog
2012/9/3:12:21:36 render RENDER1 Installing DirectX® Runtime: C:\Documents and Settings\render\Desktop\3dsmax2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/9/3:12:23:00 render RENDER1 Install DirectX® Runtime Succeeded
2012/9/3:12:23:00 render RENDER1 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Documents and Settings\render\Desktop\3dsmax2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/9/3:12:23:31 render RENDER1 Install Autodesk Material Library 2013 Succeeded
2012/9/3:12:23:31 render RENDER1 Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Documents and Settings\render\Desktop\3dsmax2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/9/3:12:23:49 render RENDER1 Install Autodesk Material Library 2013 - Base Image Library Succeeded
2012/9/3:12:23:49 render RENDER1 Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Documents and Settings\render\Desktop\3dsmax2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/9/3:12:24:57 render RENDER1 Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/9/3:12:24:59 render RENDER1 Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\DOCUME~1\render\LOCALS~1\Temp\_AI4.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Documents and Settings\render\Desktop\3dsmax2013\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/9/3:12:25:25 render RENDER1 Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2012/9/3:12:25:36 render RENDER1 Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/9/3:12:25:49 render RENDER1 Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2012/9/3:12:26:12 render RENDER1 Rollback Autodesk Material Library 2013 Succeeded
2012/9/3:12:26:12 render RENDER1 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Try to use another user with admin right to login your system and then install.
If still have problem, try to install under diagnostic mode: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2893432&linkID=9240617
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Thanks Emily!
I ended up upgrading to windows 7
Should I make a new thread for my problem below?
Now when I open 3dsmax 2013 it takes about 3min to load and uses 475 024k while loading. When open the render dialog it also takes 3min to load.
latest update installed
Updated to version 15.5.121.0 (3dsMax2013_PU05_Win_64-bit)
E
That does not sound abnormal to me. Many of those factors will be based on if your hardware meets system requirements.
Thanks for your reply TravisNave.
I have never waited this long for max to startup. Its a empty scene. When I open the render dialog it takes another 3 min.... not to render anything just to open it.
Any help will be apreciated
E
Looks like this has something to do with Vray. Re installed everything. Max 2013 take 17 sec to start up without vray... with vray it takes 2 30 min . Will head over to the chaos group forum.
E
