Installation & Licensing
Matchmover 2012 Standalone with Maya 2012 Standalone - Error [-1359.2]
12 REPLIES 12
Message 1 of 13
david.lau
5934 Views, 12 Replies
When you launch Matchmover 2012 Standalone, you may get this error:
A valid license could not be obtained by the network license manager.
If you are still unable to access a license, contact your system administrator.
Error [-1.359.2]
To solve this problem, you will need to copy the License.env file from the Maya application folder into the Matchmover application folder.
  1. Applications > Autodesk > Maya2012 > right click on Maya and select ‘Show package contents’ > Contents > Copy License.env.
  2. Applications > Autodesk > MatchMover2012 > right click on Matchmover2012 and select ‘Show Package Contents’ > Contents > Paste the License.env.
David Lau
12 REPLIES 12
Message 2 of 13
canicetti
in reply to: david.lau
Thanks!  Worked great!
Message 3 of 13
this also worked perfectly for me and was very simple and easy to follow your instructions. thanks.
Message 4 of 13
Thank you very much! This worked like a charm.
Message 5 of 13
eliud.gonzales
It did not work with Maya 2013 for Mac OS X.
Message 6 of 13
ian_zeigler
I couldnt get it to work for Match Mover 2013 on OSX either ?  : (
Message 7 of 13
michellehackett
Getting this same error message in an installation of the ADA achedemic suite. Please reccomend a solution transferable to this software.
Message 8 of 13
ian_zeigler
does anyone know how to fix this so i can actuallly use Matchmover 2013?
Message 9 of 13
david.lau
Just an update that there appears to be an issue with Matchmover 2013 on the Mac.  The development team is aware of the issue.
Please stay tuned.....
David Lau
Message 10 of 13
chocotrucco
It didn't work with Matchmover 2013,  any news on when this is going to be fixed?
Thanks so much!
(Just bought the software)
Message 11 of 13
Any update on the Matchmover 2013 license issue? Shall I switch to Maya 2012? Please advise. Feel free to answer Yes/No/Don't know.
Thanks a lot.
Maya
Message 12 of 13
david.lau
Message 13 of 13
jamesajdavies
Hi im useing match mover 13 on mac and tryed the copy past thing didnt work. ps composite won't even open. Here the error code for composite and i've attached a pic of  Matchmover
Process: Composite [8342]
Path: /Applications/Composite.app/Contents/MacOS/Composite
Identifier: com.autodesk.composite2013
Version: 2600
Code Type: X86-64 (Native)
Parent Process: launchd [297]
User ID: 501
Date/Time: 2013-03-29 18:29:52.246 +0000
OS Version: Mac OS X 10.8.3 (12D78)
Report Version: 10
Interval Since Last Report: 191989 sec
Crashes Since Last Report: 8
Per-App Crashes Since Last Report: 7
Anonymous UUID: 907B28EC-ED93-5E20-E223-E26D0F1AB3CC
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
terminate called throwing an exception
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff986db212 __pthread_kill + 10
1 libsystem_c.dylib 0x00007fff9206cb54 pthread_kill + 90
2 libsystem_c.dylib 0x00007fff920b0dce abort + 143
3 libc++abi.dylib 0x00007fff91f229eb abort_message + 257
4 libc++abi.dylib 0x00007fff91f2039a default_terminate() + 28
5 libobjc.A.dylib 0x00007fff8c79e887 _objc_terminate() + 111
6 libc++abi.dylib 0x00007fff91f203c9 safe_handler_caller(void (*)()) + 8
7 libc++abi.dylib 0x00007fff91f20424 std::terminate() + 16
8 libc++abi.dylib 0x00007fff91f2158b __cxa_throw + 111
9 libDLbase.dylib 0x000000010784af6f Dl::InInitGuard::InInitGuard(int&, char const* const*&, Dl::InInitGuard::NoCallStack) + 927
10 libDLtxapp.dylib 0x00000001000a561f Dl::ApplicationBuilder::execute() + 1423
11 libDLtxapp.dylib 0x00000001000b119a txappmain + 90
12 com.autodesk.composite2013 0x00000001000039fe main + 862
13 com.autodesk.composite2013 0x0000000100003674 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff986dbd16 kevent + 10
1 libdispatch.dylib 0x00007fff9475bdea _dispatch_mgr_invoke + 883
2 libdispatch.dylib 0x00007fff9475b9ee _dispatch_mgr_thread + 54
Thread 2:
0 libsystem_kernel.dylib 0x00007fff986db6d6 __workq_kernreturn + 10
1 libsystem_c.dylib 0x00007fff9206df4c _pthread_workq_return + 25
2 libsystem_c.dylib 0x00007fff9206dd13 _pthread_wqthread + 412
3 libsystem_c.dylib 0x00007fff920581d1 start_wqthread + 13
Thread 3:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff5fbfe088 rdx: 0x0000000000000000
rdi: 0x0000000000000c07 rsi: 0x0000000000000006 rbp: 0x00007fff5fbfe0b0 rsp: 0x00007fff5fbfe088
r8: 0x00007fff7c77b278 r9: 0x0000000000000017 r10: 0x0000000020000000 r11: 0x0000000000000206
r12: 0x00007fff5fbfe210 r13: 0x00007fff5fbff770 r14: 0x00007fff7c77c180 r15: 0x00007fff5fbfe0f0
rip: 0x00007fff986db212 rfl: 0x0000000000000206 cr2: 0x00007fff7c774ff0
Logical CPU: 0
Binary Images:
0x100000000 - 0x100005fef +com.autodesk.composite2013 (2600) <80FE6A1D-3151-D5B0-84B3-06FC25E94A7E> /Applications/Composite.app/Contents/MacOS/Composite
0x10009a000 - 0x1000b7ff7 +libDLtxapp.dylib (0) <279C3C49-4E3A-6D4F-36E5-B5EF43EAAAC0> /Applications/Composite.app/Contents/Resources/Libraries/libDLtxapp.dylib
0x1000da000 - 0x1000e8ff2 +libGLUtess.dylib (0) <65BA6B29-996B-00B8-CC3B-7EE93E4E53A5> /Applications/Composite.app/Contents/Resources/Libraries/libGLUtess.dylib
0x100400000 - 0x10049cfff +libDLappCore.dylib (0) <0642CBEA-4DAB-46EB-AA5D-B442AB34D8D3> /Applications/Composite.app/Contents/Resources/Libraries/libDLappCore.dylib
0x100545000 - 0x100619ff7 +libDLrender.dylib (0) <6AF46CC8-5F42-755C-3242-84C1412D3308> /Applications/Composite.app/Contents/Resources/Libraries/libDLrender.dylib
0x1006cd000 - 0x1006f4ff7 +libDLscriptingAPI.dylib (0) <FEF13E5E-CF27-63A3-07F4-A32CB491A293> /Applications/Composite.app/Contents/Resources/Libraries/libDLscriptingAPI.dylib
0x100730000 - 0x10076afff +libboost_python-xgcc40-mt-1_38.dylib (0) <9C6D6F57-7560-E91C-AED8-987823238E9D> /Applications/Composite.app/Contents/Resources/Libraries/libboost_python-xgcc40-mt-1_38.dylib
0x101000000 - 0x101782ff7 +libDLappUi.dylib (0) <BC541A71-EC03-CF52-1C25-9F7604AEB761> /Applications/Composite.app/Contents/Resources/Libraries/libDLappUi.dylib
0x101f68000 - 0x10249ffe7 +libDLui.dylib (0) <EA576D4E-0BE9-2D6F-58F0-94CF55645962> /Applications/Composite.app/Contents/Resources/Libraries/libDLui.dylib
0x102a7b000 - 0x102d2cff7 +libDLgfx.dylib (0) <0C5D67EE-C8BD-8C22-B0E3-B7C00B6DEBA0> /Applications/Composite.app/Contents/Resources/Libraries/libDLgfx.dylib
0x1030d5000 - 0x1033f9fff +libDLbuiltinTools.dylib (0) <35B2B34E-3218-0B6A-6590-F3CE1BA8D6F9> /Applications/Composite.app/Contents/Resources/Libraries/libDLbuiltinTools.dylib
0x103890000 - 0x103e62ff7 +libDLdatamgt.dylib (0) <65476875-0B62-4FC0-B918-59D800BDBDB3> /Applications/Composite.app/Contents/Resources/Libraries/libDLdatamgt.dylib
0x1044b3000 - 0x10461efef +libDLmedia.dylib (0) <DFC99BF4-0AE5-1F34-A8C3-B24B23C37029> /Applications/Composite.app/Contents/Resources/Libraries/libDLmedia.dylib
0x1046e4000 - 0x10478eff7 +libDLframework.dylib (0) <0B382DFB-BC39-F6A6-DD5E-13BDBDC55D6C> /Applications/Composite.app/Contents/Resources/Libraries/libDLframework.dylib
0x10485d000 - 0x104901fff +libDLstorage.dylib (0) <BE729315-8949-3E36-A920-7EAE24AB3F24> /Applications/Composite.app/Contents/Resources/Libraries/libDLstorage.dylib
0x104995000 - 0x10509efef +libDLinternalAPI.dylib (0) <0467024C-8E9E-124D-D073-6F8F94305380> /Applications/Composite.app/Contents/Resources/Libraries/libDLinternalAPI.dylib
0x105a92000 - 0x105e6aff7 +libDLprimitives.dylib (0) <D8CC8098-F11A-88B9-4EA5-274383206D49> /Applications/Composite.app/Contents/Resources/Libraries/libDLprimitives.dylib
0x1063bd000 - 0x1066e6fe7 +libDLresmgt.dylib (0) <FC3EA8DB-6516-2368-6695-972396E262EA> /Applications/Composite.app/Contents/Resources/Libraries/libDLresmgt.dylib
0x106a52000 - 0x106fa9fff +libDLpluginAPI.dylib (0) <FA659919-3996-60D7-8F9F-6B4FFA7BCBBC> /Applications/Composite.app/Contents/Resources/Libraries/libDLpluginAPI.dylib
0x1076f5000 - 0x107912fff +libDLbase.dylib (0) <98C38F15-28E9-ABE2-19C0-22157194E0EF> /Applications/Composite.app/Contents/Resources/Libraries/libDLbase.dylib
0x107b90000 - 0x107ec3ff7 +libadlmint.dylib (5.0.39) <7471F34F-FBE0-A56B-6752-1AD4A7D667A1> /Applications/Composite.app/Contents/Resources/Libraries/libadlmint.dylib
0x1080f1000 - 0x1081dafff +libADUT.dylib (1.0.31) <F825BC52-C782-C647-7A3F-DC32D066CE20> /Applications/Composite.app/Contents/Resources/Libraries/libADUT.dylib
0x108327000 - 0x10847cfef +org.python.python (2.6.4, [c] 2004-2008 Python Software Foundation. - 2.6.4) <B26B57DC-C859-B013-8814-DE24855E5F53> /Applications/Composite.app/Contents/Frameworks/Python.framework/Versions/2.6/Python
0x10854e000 - 0x108647ffa +libdb_cxx.dylib (0) <9C0D1F03-53F2-211F-BBAB-ACEEF1F67122> /Applications/Composite.app/Contents/Resources/Libraries/libdb_cxx.dylib
0x7fff6e099000 - 0x7fff6e0cd93f dyld (210.2.3) <A40597AA-5529-3337-8C09-D8A014EB1578> /usr/lib/dyld
0x7fff8ba31000 - 0x7fff8ba6cfff com.apple.LDAPFramework (2.4.28 - 194.5) <67FBDB29-3B9F-309A-BA7C-AA5921D9A4FB> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff8ba6d000 - 0x7fff8baa4ff7 libssl.0.9.8.dylib (47) <923945E6-C489-3406-903B-A362410753F8> /usr/lib/libssl.0.9.8.dylib
0x7fff8badb000 - 0x7fff8baf2fff com.apple.GenerationalStorage (1.1 - 132.3) <FD4A84B3-13A8-3C60-A59E-25A361447A17> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff8baf3000 - 0x7fff8c4836ff com.apple.CoreGraphics (1.600.0 - 331.0.4) <4953961C-96DC-39D7-ADF5-B767F2A7E4E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8c484000 - 0x7fff8c495ff7 libsasl2.2.dylib (166) <649CAE0E-8FFE-3C60-A849-BE6300E4B726> /usr/lib/libsasl2.2.dylib
0x7fff8c496000 - 0x7fff8c73aff7 com.apple.CoreImage (8.2.4 - 1.0.1) <4A6B017F-B9F7-36DA-943D-A95611F147EA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff8c748000 - 0x7fff8c78cfff libcups.2.dylib (327.3) <71E771A1-0489-3417-8A4A-56A2C930F80C> /usr/lib/libcups.2.dylib
0x7fff8c78d000 - 0x7fff8c8a592f libobjc.A.dylib (532.2) <90D31928-F48D-3E37-874F-220A51FD9E37> /usr/lib/libobjc.A.dylib
0x7fff8c8a6000 - 0x7fff8ca17ff7 com.apple.QTKit (7.7.1 - 2599.24) <A2153722-268B-3293-B9E3-CB59273CDE41> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff8d9d6000 - 0x7fff8da0cfff com.apple.DebugSymbols (98 - 98) <14E788B1-4EB2-3FD7-934B-849534DFC198> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff8da0d000 - 0x7fff8da75ff7 libc++.1.dylib (65.1) <20E31B90-19B9-3C2A-A9EB-474E08F9FE05> /usr/lib/libc++.1.dylib
0x7fff8dbf0000 - 0x7fff8dbfcfff com.apple.CrashReporterSupport (10.8.3 - 417) <48EDDDF3-5720-39D6-B51F-D9AFB93327B3> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff8dc4f000 - 0x7fff8dca9fff com.apple.print.framework.PrintCore (8.3 - 387.2) <5BA0CBED-4D80-386A-9646-F835C9805B71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8dcaa000 - 0x7fff8dcd6fff com.apple.framework.Apple80211 (8.3.2 - 832.18.1) <5D601780-9AD9-31C9-9AB5-716D8634CB78> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8de63000 - 0x7fff8e063fff libicucore.A.dylib (491.11.2) <FD6282D8-DF3F-3842-8C2E-CF478D2B9669> /usr/lib/libicucore.A.dylib
0x7fff8e064000 - 0x7fff8e06cff7 libsystem_dnssd.dylib (379.37) <616FC901-151E-38BF-B2C4-24A351C5FAAD> /usr/lib/system/libsystem_dnssd.dylib
0x7fff8e1c7000 - 0x7fff8e1f2fff libxslt.1.dylib (11.3) <441776B8-9130-3893-956F-39C85FFA644F> /usr/lib/libxslt.1.dylib
0x7fff8e8b0000 - 0x7fff8e8b9ff7 com.apple.CommerceCore (1.0 - 26.1) <40A129A8-4E5D-3C7A-B299-8CB203C4C65D> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff8f170000 - 0x7fff8f17dfff libbz2.1.0.dylib (29) <CE9785E8-B535-3504-B392-82F0064D9AF2> /usr/lib/libbz2.1.0.dylib
0x7fff8f186000 - 0x7fff8f18bfff libcache.dylib (57) <65187C6E-3FBF-3EB8-A1AA-389445E2984D> /usr/lib/system/libcache.dylib
0x7fff8f234000 - 0x7fff8f2a2fff com.apple.framework.IOKit (2.0.1 - 755.22.5) <1547DA6F-9793-30A2-8E92-7368DE84D46C> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8f2a3000 - 0x7fff8f3aefff libFontParser.dylib (84.6) <96C42E49-79A6-3475-B5E4-6A782599A6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8f3bb000 - 0x7fff8f3c3fff liblaunch.dylib (442.26.2) <2F71CAF8-6524-329E-AC56-C506658B4C0C> /usr/lib/system/liblaunch.dylib
0x7fff8f3c4000 - 0x7fff8f3dbfff com.apple.CFOpenDirectory (10.8 - 151.10) <FFBBA538-00B5-334E-BA5B-C8AD6CDCDA14> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff8f46f000 - 0x7fff8f589fff com.apple.coreavchd (5.6.0 - 5600.4.16) <0CF2ABE5-B088-3B5D-9C04-47AE708ADAE3> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff8f58a000 - 0x7fff8f5b2fff libJPEG.dylib (849) <5C9052F6-D0B3-39CC-8302-468B43D694D5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff8f5b9000 - 0x7fff8f9f5fff com.apple.VideoToolbox (1.0 - 926.87) <7319477A-4A3D-3233-AAD1-31F9C9429DA7> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff8f9f6000 - 0x7fff8fa0dfff libGL.dylib (8.7.25) <15F5CB64-847B-3D3D-9663-E0523F15F513> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8fa0e000 - 0x7fff901b5fff com.apple.CoreAUC (6.16.13 - 6.16.13) <8CBFBC9C-0773-3DEB-AF99-989008CB2B36> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff90239000 - 0x7fff9046eff7 com.apple.CoreData (106.1 - 407.7) <24E0A6B4-9ECA-3D12-B26A-72B9DCF09768> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff9046f000 - 0x7fff90491ff7 libxpc.dylib (140.42) <BBE558BD-5E55-35E4-89ED-1AA6B056D05A> /usr/lib/system/libxpc.dylib
0x7fff90492000 - 0x7fff904dbfff com.apple.framework.CoreWiFi (1.2.2 - 122.12) <D237551E-0E2C-30FB-8FAA-003D8F25E819> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff9068e000 - 0x7fff906ebff7 com.apple.audio.CoreAudio (4.1.1 - 4.1.1) <D15F3FB3-BE53-3545-AD37-9A25A597FE3C> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff906ec000 - 0x7fff906f7fff libsystem_notify.dylib (98.5) <C49275CC-835A-3207-AFBA-8C01374927B6> /usr/lib/system/libsystem_notify.dylib
0x7fff907e3000 - 0x7fff907e4fff liblangid.dylib (116) <864C409D-D56B-383E-9B44-A435A47F2346> /usr/lib/liblangid.dylib
0x7fff9084e000 - 0x7fff908a3ff7 libTIFF.dylib (849) <C4D0E196-9319-319B-AF72-8B63FB5AF71B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff9092e000 - 0x7fff90997fff libstdc++.6.dylib (56) <EAA2B53E-EADE-39CF-A0EF-FB9D4940672A> /usr/lib/libstdc++.6.dylib
0x7fff90998000 - 0x7fff909c9ff7 com.apple.DictionaryServices (1.2 - 184.4) <054F2D6F-9CFF-3EF1-9778-25C551B616C1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff909d5000 - 0x7fff90dcefe7 com.apple.MediaToolbox (1.0 - 926.87) <8346DAFC-88E5-350E-90E1-C98B180488C2> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff90e3e000 - 0x7fff90e98ff7 com.apple.opencl (2.2.18 - 2.2.18) <4A78E53C-17B0-3B2D-A9EA-EF8720FE4134> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff91397000 - 0x7fff9139dfff com.apple.DiskArbitration (2.5.2 - 2.5.2) <C713A35A-360E-36CE-AC0A-25C86A3F50CA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff9139e000 - 0x7fff913a2fff libpam.2.dylib (20) <C8F45864-5B58-3237-87E1-2C258A1D73B8> /usr/lib/libpam.2.dylib
0x7fff913e8000 - 0x7fff913effff libGFXShared.dylib (8.7.25) <869580B2-39CB-30C3-B76E-73BB4894B6B7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff91a0f000 - 0x7fff91a60ff7 com.apple.SystemConfiguration (1.12.2 - 1.12.2) <A4341BBD-A330-3A57-8891-E9C1A286A72D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff91a7d000 - 0x7fff91b0aff7 com.apple.SearchKit (1.4.0 - 1.4.0) <C7F43889-F8BF-3CB9-AD66-11AEFCBCEDE7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff91b0b000 - 0x7fff91c2bfff com.apple.desktopservices (1.7.3 - 1.7.3) <707F77D2-EC0E-3431-840F-B984BD7ABDD6> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff91f1f000 - 0x7fff91f44ff7 libc++abi.dylib (26) <D86169F3-9F31-377A-9AF3-DB17142052E4> /usr/lib/libc++abi.dylib
0x7fff91f45000 - 0x7fff91f47fff com.apple.TrustEvaluationAgent (2.0 - 23) <A97D348B-32BF-3E52-8DF2-59BFAD21E1A3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff91f77000 - 0x7fff91f8bfff com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <94EDF2AB-809C-3D15-BED5-7AD45B2A7C16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff91f8e000 - 0x7fff91fabff7 com.apple.openscripting (1.3.6 - 148.3) <C008F56A-1E01-3D4C-A9AF-97799D0FAE69> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff91fac000 - 0x7fff92003ff7 com.apple.AppleVAFramework (5.0.19 - 5.0.19) <541A7DBE-F8E4-3023-A3C0-8D5A2A550CFB> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff92004000 - 0x7fff92032ff7 libsystem_m.dylib (3022.6) <B434BE5C-25AB-3EBD-BAA7-5304B34E3441> /usr/lib/system/libsystem_m.dylib
0x7fff92040000 - 0x7fff92041ff7 libremovefile.dylib (23.2) <6763BC8E-18B8-3AD9-8FFA-B43713A7264F> /usr/lib/system/libremovefile.dylib
0x7fff92057000 - 0x7fff92123ff7 libsystem_c.dylib (825.26) <4C9EB006-FE1F-3F8F-8074-DFD94CF2CE7B> /usr/lib/system/libsystem_c.dylib
0x7fff921c4000 - 0x7fff92521ff7 com.apple.Foundation (6.8 - 945.16) <89BD68FD-72C8-35C1-94C6-3A07F097C50D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff926a7000 - 0x7fff926b9ff7 libz.1.dylib (43) <2A1551E8-A272-3DE5-B692-955974FE1416> /usr/lib/libz.1.dylib
0x7fff926ba000 - 0x7fff92818fef com.apple.MediaControlSender (1.7 - 170.20) <853BE89D-49B0-3922-9ED5-DDBDE9A97356> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x7fff92819000 - 0x7fff9281fff7 libunwind.dylib (35.1) <21703D36-2DAB-3D8B-8442-EAAB23C060D3> /usr/lib/system/libunwind.dylib
0x7fff92832000 - 0x7fff92834fff libCVMSPluginSupport.dylib (8.7.25) <A45E21E3-4B40-39B0-A8B6-411526A84F47> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff92835000 - 0x7fff9283cfff com.apple.NetFS (5.0 - 4.0) <82E24B9A-7742-3DA3-9E99-ED267D98C05E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff92894000 - 0x7fff92895ff7 libsystem_sandbox.dylib (220.2) <6838A6FD-8626-3356-BB4F-BB4787216207> /usr/lib/system/libsystem_sandbox.dylib
0x7fff92965000 - 0x7fff92c95fff com.apple.HIToolbox (2.0 - 626.1) <656D08C2-9068-3532-ABDD-32EC5057CCB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff92c96000 - 0x7fff92cedff7 com.apple.ScalableUserInterface (1.0 - 1) <F1D43DFB-1796-361B-AD4B-39F1EED3BE19> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x7fff92cee000 - 0x7fff92d03fff com.apple.ImageCapture (8.0 - 8.0) <17A45CE6-7DA3-36A5-B7EF-72BC136981AE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff92d04000 - 0x7fff92d04fff com.apple.Carbon (154 - 155) <372716D2-6FA1-3611-8501-3DD1D4A6E8C8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff92d05000 - 0x7fff92e56fff com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <C680EE1A-B4ED-3E77-A08C-DC47922ACA33> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff92e57000 - 0x7fff92e57fff com.apple.Accelerate (1.8 - Accelerate 1.8) <6AD48543-0864-3D40-80CE-01F184F24B45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff92f11000 - 0x7fff92f12ff7 libSystem.B.dylib (169.3) <365477AB-D641-389D-B8F4-A1FAE9657EEE> /usr/lib/libSystem.B.dylib
0x7fff92f13000 - 0x7fff92f32ff7 com.apple.ChunkingLibrary (2.0 - 133.3) <8BEC9AFB-DCAA-37E8-A5AB-24422B234ECF> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff92f33000 - 0x7fff92fb4fff com.apple.Metadata (10.7.0 - 707.5) <4140B1F6-7D73-33C7-B3F2-4DB349C31AE9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff92fb5000 - 0x7fff92fdcfff com.apple.framework.familycontrols (4.1 - 410) <50F5A52C-8FB6-300A-977D-5CFDE4D5796B> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff92fdd000 - 0x7fff930dffff libJP2.dylib (849) <4EEA33EB-AF9F-365D-A572-F7D11AD1C76F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff930e0000 - 0x7fff931b2ff7 com.apple.CoreText (260.0 - 275.16) <5BFC1D67-6A6F-38BC-9D90-9C712684EDAC> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff93452000 - 0x7fff93465ff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <2F2694E9-A7BC-33C7-B4CF-8EC907DF0FEB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff9346b000 - 0x7fff9348cfff com.apple.Ubiquity (1.2 - 243.15) <C9A7EE77-B637-3676-B667-C0843BBB0409> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x7fff9348d000 - 0x7fff93491fff com.apple.IOSurface (86.0.4 - 86.0.4) <26F01CD4-B76B-37A3-989D-66E8140542B3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff93492000 - 0x7fff934d5ff7 com.apple.bom (12.0 - 192) <0BF1F2D2-3648-36B7-BE4B-551A0173209B> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff934d6000 - 0x7fff934f6fff libPng.dylib (849) <F4C23A55-F17B-3E4F-9E80-BC97F778BA49> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff934f7000 - 0x7fff935a8fff com.apple.LaunchServices (539.7 - 539.7) <DA7C602E-5E01-31B8-925D-B45360CA089F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff935a9000 - 0x7fff935acfff com.apple.help (1.3.2 - 42) <343904FE-3022-3573-97D6-5FE17F8643BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff935b9000 - 0x7fff938d0ff7 com.apple.CoreServices.CarbonCore (1037.5 - 1037.5) <731D8F92-1C52-3613-BA01-EFEA54DADF41> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff939c7000 - 0x7fff93a16ff7 libcorecrypto.dylib (106.2) <CE0C29A3-C420-339B-ADAA-52F4683233CC> /usr/lib/system/libcorecrypto.dylib
0x7fff93a17000 - 0x7fff93a17fff libkeymgr.dylib (25) <CC9E3394-BE16-397F-926B-E579B60EE429> /usr/lib/system/libkeymgr.dylib
0x7fff93a18000 - 0x7fff93e0ffff libLAPACK.dylib (1073.4) <D632EC8B-2BA0-3853-800A-20DA00A1091C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff93e10000 - 0x7fff93e23ff7 libbsm.0.dylib (32) <F497D3CE-40D9-3551-84B4-3D5E39600737> /usr/lib/libbsm.0.dylib
0x7fff93ef8000 - 0x7fff93f47ff7 libFontRegistry.dylib (100) <2E03D7DA-9B8F-31BB-8FB5-3D3B6272127F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff93f62000 - 0x7fff93f65fff libRadiance.dylib (849) <F7D9A0FD-1195-34CB-BFE5-79DAF3F40AC3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff93f66000 - 0x7fff93f6bfff com.apple.OpenDirectory (10.8 - 151.10) <CF44120B-9B01-32DD-852E-C9C0E1243FC0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff93f6c000 - 0x7fff93f70fff libCoreVMClient.dylib (32.3) <AD8391D9-56DD-3A78-A294-6A30E6ECE1A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff93f71000 - 0x7fff93f72fff libsystem_blocks.dylib (59) <D92DCBC3-541C-37BD-AADE-ACC75A0C59C8> /usr/lib/system/libsystem_blocks.dylib
0x7fff93f73000 - 0x7fff94068fff libiconv.2.dylib (34) <FEE8B996-EB44-37FA-B96E-D379664DEFE1> /usr/lib/libiconv.2.dylib
0x7fff94069000 - 0x7fff94182fff com.apple.ImageIO.framework (3.2.0 - 849) <C52AED41-A7C2-300B-91FA-5AF73718D243> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff94183000 - 0x7fff941ebfff libvDSP.dylib (380.6) <CD4C5EEB-9E63-30C4-8103-7A5EAEA0BE60> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff9449f000 - 0x7fff94689ff7 com.apple.CoreFoundation (6.8 - 744.18) <A60C3C9B-3764-3291-844C-C487ACF77C2C> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff9468a000 - 0x7fff946d6ff7 libauto.dylib (185.1) <73CDC482-16E3-3FC7-9BB4-FBA2DA44DBC2> /usr/lib/libauto.dylib
0x7fff946d7000 - 0x7fff946d7fff com.apple.CoreServices (57 - 57) <9DD44CB0-C644-35C3-8F57-0B41B3EC147D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff946d8000 - 0x7fff946e3ff7 com.apple.bsd.ServiceManagement (2.0 - 2.0) <C12962D5-85FB-349E-AA56-64F4F487F219> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff946e4000 - 0x7fff946e8ff7 com.apple.TCC (1.0 - 1) <F2F3B753-FC73-3543-8BBE-859FDBB4D6A6> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff946e9000 - 0x7fff94756ff7 com.apple.datadetectorscore (4.1 - 269.2) <4FD4A7CE-BB00-3AAB-B7AA-AE395D5400EC> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff94757000 - 0x7fff9476cff7 libdispatch.dylib (228.23) <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
0x7fff9476d000 - 0x7fff9476dfff libOpenScriptingUtil.dylib (148.3) <F8681222-0969-3B10-8BCE-C55A4B9C520C> /usr/lib/libOpenScriptingUtil.dylib
0x7fff9476e000 - 0x7fff94778fff com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <D803919C-3102-3515-A178-61E9C86C46A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff94809000 - 0x7fff94817fff libcommonCrypto.dylib (60027) <BAAFE0C9-BB86-3CA7-88C0-E3CBA98DA06F> /usr/lib/system/libcommonCrypto.dylib
0x7fff94818000 - 0x7fff94826ff7 libsystem_network.dylib (77.10) <0D99F24E-56FE-380F-B81B-4A4C630EE587> /usr/lib/system/libsystem_network.dylib
0x7fff94842000 - 0x7fff948a1fff com.apple.AE (645.6 - 645.6) <44F403C1-660A-3543-AB9C-3902E02F936F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff948a2000 - 0x7fff948d8fff libsystem_info.dylib (406.17) <4FFCA242-7F04-365F-87A6-D4EFB89503C1> /usr/lib/system/libsystem_info.dylib
0x7fff948d9000 - 0x7fff948dffff libmacho.dylib (829) <BF332AD9-E89F-387E-92A4-6E1AB74BD4D9> /usr/lib/system/libmacho.dylib
0x7fff950fc000 - 0x7fff95109fff com.apple.AppleFSCompression (49 - 1.0) <5508344A-2A7E-3122-9562-6F363910A80E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff9510a000 - 0x7fff95129ff7 libresolv.9.dylib (51) <0882DC2D-A892-31FF-AD8C-0BB518C48B23> /usr/lib/libresolv.9.dylib
0x7fff9519b000 - 0x7fff951d8fef libGLImage.dylib (8.7.25) <139A9892-A6F2-3F49-87FB-E7AC3F56E003> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff95231000 - 0x7fff95235fff libGIF.dylib (849) <6A664B4D-0A88-33F7-9064-0CD159AB9CE9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff95259000 - 0x7fff9526ffff com.apple.MultitouchSupport.framework (235.29 - 235.29) <617EC8F1-BCE7-3553-86DD-F857866E1257> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff95529000 - 0x7fff95626fff libsqlite3.dylib (138.1) <ADE9CB98-D77D-300C-A32A-556B7440769F> /usr/lib/libsqlite3.dylib
0x7fff95627000 - 0x7fff9567dfff com.apple.HIServices (1.20 - 417) <A1129272-FEC8-350B-BA26-5A97F23C413D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff9567e000 - 0x7fff956fcff7 com.apple.securityfoundation (6.0 - 55115.4) <C5461971-E455-31A6-99B8-AF80C4BC26DD> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff956fd000 - 0x7fff95898fef com.apple.vImage (6.0 - 6.0) <FAE13169-295A-33A5-8E6B-7C2CC1407FA7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff958cd000 - 0x7fff95ceafff FaceCoreLight (2.4.1) <A34C9575-C4C1-31B1-809B-7751070B4E8B> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x7fff95ceb000 - 0x7fff95d33fff libcurl.4.dylib (69.2) <EBDBF42D-E4A6-3D05-A76B-2817D79D59E2> /usr/lib/libcurl.4.dylib
0x7fff95d34000 - 0x7fff95d42ff7 libkxld.dylib (2050.22.13) <4AAF0573-8632-3D06-BE32-C5675F77638D> /usr/lib/system/libkxld.dylib
0x7fff95d43000 - 0x7fff95d50ff7 com.apple.NetAuth (4.0 - 4.0) <F5BC7D7D-AF28-3C83-A674-DADA48FF7810> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff95df6000 - 0x7fff95f6bfff com.apple.CFNetwork (596.3.3 - 596.3.3) <3739DC8D-8610-3740-80EC-43E130779CB8> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff95f90000 - 0x7fff96092fff libcrypto.0.9.8.dylib (47) <74F165AD-4572-3B26-B0E2-A97477FE59D0> /usr/lib/libcrypto.0.9.8.dylib
0x7fff96093000 - 0x7fff96cc0ff7 com.apple.AppKit (6.8 - 1187.37) <FAEA8B77-210F-3C0F-B9CF-85A7595CCA26> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff96cc1000 - 0x7fff96dbeff7 libxml2.2.dylib (22.3) <47B09CB2-C636-3024-8B55-6040F7829B4C> /usr/lib/libxml2.2.dylib
0x7fff96dbf000 - 0x7fff96e5afff com.apple.CoreSymbolication (3.0 - 117) <C304FDB8-2FF7-34BC-858A-2B96C2B039D5> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff96f86000 - 0x7fff96fd3fff com.apple.CoreMediaIO (307.0 - 4155) <CD826A65-DFE7-3A58-A29E-15B3A9BE0A6D> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff97065000 - 0x7fff9710bff7 com.apple.CoreServices.OSServices (557.6 - 557.6) <1BDB5456-0CE9-301C-99C1-8EFD0D2BFCCD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff9711b000 - 0x7fff9719dff7 com.apple.Heimdal (3.0 - 2.0) <C94B0C6C-1320-35A1-8143-FE252E7B2A08> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff97273000 - 0x7fff97281fff com.apple.Librarian (1.1 - 1) <5AC28666-7642-395F-A923-C6F8A274BBBD> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x7fff97503000 - 0x7fff97504ff7 libdnsinfo.dylib (453.19) <14202FFB-C3CA-3FCC-94B0-14611BF8692D> /usr/lib/system/libdnsinfo.dylib
0x7fff97505000 - 0x7fff976b3fff com.apple.QuartzCore (1.8 - 304.2) <234EABE1-067C-3DAE-BEAC-674526E232C2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff976e6000 - 0x7fff976eaff7 com.apple.CommonPanels (1.2.5 - 94) <AAC003DE-2D6E-38B7-B66B-1F3DA91E7245> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff97714000 - 0x7fff9774eff7 com.apple.GSS (3.0 - 2.0) <970CAE00-1437-3F4E-B677-0FDB3714C08C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff9774f000 - 0x7fff9774ffff com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <B5A18EE8-DF81-38DD-ACAF-7076B2A26225> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff97750000 - 0x7fff97753ff7 libdyld.dylib (210.2.3) <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
0x7fff978da000 - 0x7fff97936ff7 com.apple.Symbolication (1.3 - 93) <F2C7E0B6-B241-3020-B30A-0636D0FA3378> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff97937000 - 0x7fff979b7ff7 com.apple.ApplicationServices.ATS (332 - 341.1) <BD83B039-AB25-3E3E-9975-A67DAE66988B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff979b8000 - 0x7fff979e2ff7 com.apple.CoreVideo (1.8 - 99.4) <E5082966-6D81-3973-A05A-38AA5B85F886> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff979e3000 - 0x7fff97a2efff com.apple.framework.CoreWLAN (3.0.2 - 302.12) <896D75EB-069B-3674-936E-27A81568BECB> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff97abe000 - 0x7fff97abffff libDiagnosticMessagesClient.dylib (8) <8548E0DC-0D2F-30B6-B045-FE8A038E76D8> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff97ac0000 - 0x7fff97ac7fff libcopyfile.dylib (89) <876573D0-E907-3566-A108-577EAD1B6182> /usr/lib/system/libcopyfile.dylib
0x7fff97ac8000 - 0x7fff97b62fff libvMisc.dylib (380.6) <714336EA-1C0E-3735-B31C-19DFDAAF6221> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff97bbe000 - 0x7fff97bd8fff com.apple.CoreMediaAuthoring (2.1 - 914) <CFA664F9-D5A7-3281-A12F-3ED8A98FD8C1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff97bd9000 - 0x7fff97cb3fff com.apple.backup.framework (1.4.2 - 1.4.2) <0B557393-CD2A-3076-BED2-F28D02E1EC1D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff97cb4000 - 0x7fff97cf3ff7 com.apple.QD (3.42 - 285) <8DF36FCA-C06B-30F4-A631-7BE2FF7E56D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff97d05000 - 0x7fff97d0afff libcompiler_rt.dylib (30) <08F8731D-5961-39F1-AD00-4590321D24A9> /usr/lib/system/libcompiler_rt.dylib
0x7fff97d0b000 - 0x7fff97da9ff7 com.apple.ink.framework (10.8.2 - 150) <84B9825C-3822-375F-BE58-A753444FBDE2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff97e48000 - 0x7fff97e57ff7 libxar.1.dylib (105) <370ED355-E516-311E-BAFD-D80633A84BE1> /usr/lib/libxar.1.dylib
0x7fff97e58000 - 0x7fff97e5aff7 libunc.dylib (25) <92805328-CD36-34FF-9436-571AB0485072> /usr/lib/system/libunc.dylib
0x7fff97f1d000 - 0x7fff980a3fff libBLAS.dylib (1073.4) <C102C0F6-8CB6-3B49-BA6B-2EB61F0B2784> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff980a4000 - 0x7fff980eeff7 libGLU.dylib (8.7.25) <C243C6D3-3384-3DB1-BB15-E27B65C87294> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff980ef000 - 0x7fff980effff com.apple.Cocoa (6.7 - 19) <1F77945C-F37A-3171-B22E-F7AB0FCBB4D4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff980f0000 - 0x7fff980fbfff com.apple.CommonAuth (3.0 - 2.0) <7A953C1F-8B18-3E46-9BEA-26D9B5B7745D> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff980fc000 - 0x7fff980fefff libquarantine.dylib (52) <4BE2E642-A14F-340A-B482-5BD2AEFD9C24> /usr/lib/system/libquarantine.dylib
0x7fff980ff000 - 0x7fff980ffffd com.apple.audio.units.AudioUnit (1.8 - 1.8) <173346B7-614C-380B-8E80-9BD1BE501674> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff98100000 - 0x7fff98100fff com.apple.ApplicationServices (45 - 45) <A3ABF20B-ED3A-32B5-830E-B37831A45A80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff98155000 - 0x7fff9817cff7 com.apple.PerformanceAnalysis (1.16 - 16) <E4888388-F41B-313E-9CBB-5807D077BDA9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff9817f000 - 0x7fff98450ff7 com.apple.security (7.0 - 55179.11) <73958084-5BBC-3597-A751-7370B0C247E5> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff98663000 - 0x7fff986a6ff7 com.apple.RemoteViewServices (2.0 - 80.6) <5CFA361D-4853-3ACC-9EFC-A2AC1F43BA4B> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff986a7000 - 0x7fff986c8ff7 libCRFSuite.dylib (33) <736ABE58-8DED-3289-A042-C25AF7AE5B23> /usr/lib/libCRFSuite.dylib
0x7fff986c9000 - 0x7fff986e4ff7 libsystem_kernel.dylib (2050.22.13) <5A961E2A-CFB8-362B-BC43-122704AEB047> /usr/lib/system/libsystem_kernel.dylib
0x7fff98770000 - 0x7fff98770fff com.apple.vecLib (3.8 - vecLib 3.8) <794317C7-4E38-338A-A874-5E18001C8503> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff98804000 - 0x7fff988c9ff7 com.apple.coreui (2.0 - 181.1) <83D2C92D-6842-3C9D-9289-39D5B4554C3A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff988ca000 - 0x7fff988ccff7 com.apple.print.framework.Print (8.0 - 258) <34666CC2-B86D-3313-B3B6-A9977AD593DA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff988cd000 - 0x7fff9898aff7 com.apple.ColorSync (4.8.0 - 4.8.0) <6CE333AE-EDDB-3768-9598-9DB38041DC55> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff9898b000 - 0x7fff989adff7 com.apple.Kerberos (2.0 - 1) <C49B8820-34ED-39D7-A407-A3E854153556> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff989ae000 - 0x7fff989f9fff com.apple.CoreMedia (1.0 - 926.87) <F51205F8-A102-359C-A9A3-22A48524C081> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff98a03000 - 0x7fff98a12fff com.apple.opengl (1.8.7 - 1.8.7) <26F7FF79-6BB2-3968-B70D-71D4E07C9551> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff98a45000 - 0x7fff98a47fff com.apple.securityhi (4.0 - 55002) <34E45C60-DC7E-3FCC-A1ED-EBF48B77C559> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 2568
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=279.1M resident=245.3M(88%) swapped_out_or_unallocated=33.9M(12%)
Writable regions: Total=51.5M written=956K(2%) resident=1580K(3%) swapped_out=0K(0%) unallocated=49.9M(97%)
REGION TYPE VIRTUAL
CG shared images 96K
MALLOC 41.5M
MALLOC guard page 48K
STACK GUARD 56.0M
Stack 9752K
VM_ALLOCATE 20K
__DATA 21.0M
__IMAGE 528K
__LINKEDIT 108.4M
__TEXT 170.7M
__UNICODE 544K
mapped file 18.1M
shared memory 12K
TOTAL 426.5M
Model: iMac12,1, BootROM IM121.0047.B1F, 4 processors, Intel Core i5, 2.7 GHz, 32 GB, SMC 1.71f22
Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1333 MHz, 0x0000, 0x4B425F38475F44335F313333335F43390000
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1333 MHz, 0x0000, 0x4B425F38475F44335F313333335F43390000
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1333 MHz, 0x0000, 0x4B425F38475F44335F313333335F43390000
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1333 MHz, 0x0000, 0x4B425F38475F44335F313333335F43390000
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.72.0-P2P
Bluetooth: Version 4.1.3f3 11349, 2 service, 18 devices, 1 incoming serial ports
Network Service: USB-MAC Controller, Ethernet, en3
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: ST31000528AS, 1 TB
Serial ATA Device: HL-DT-STDVDRW GA32N
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x850b, 0xfa200000 / 3
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 5
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfd110000 / 4
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
Administrator Productivity
