Installation & Licensing
MapGuide Enterprise 2011 x64 - Invalide license
3 REPLIES 3
1314 Views, 3 Replies
I have a serious problem with installation of MapGuide Enterprise 2011 x64 on Windows Server 2008 x64 with IIS 7.
Short description of problem:
A. Installation in evaluation mode - everything works OK.
B. Installation in license mode - problems 😞
1. Verifying the Configuration  - only testing the site administrator works. For other tests server issue mesage "Invalide license".
2. Firewall is not a problem (no change with turned off) - pport 2080 and 27000 available.
3. License manager working correctly but obviously can't connect Mapguide server (or vice versa)
Status
Flexible License Manager status on Wed 6/23/2010 23:04
[Detecting lmgrd processes...]
License server status: 27000@atlas
    License file(s) on atlas: C:\Program Files\Autodesk Network License Manager\autocad.lic:
     atlas: license server UP (MASTER) v11.7
Vendor daemon status (on atlas):
  adskflex: UP v11.7
Feature usage info:
Users of 85552MAPGE_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Bundled installation gave the same result - not working,
There are no other flexnet license managers installed on server.
Searching the forums didn't find help fo my problem.
Thank you for any advise.
3 REPLIES 3
DarrenP
did you try this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10976858&linkID=9240978
DarrenP
in reply to: DarrenP
Thank you for the link to this update.
It is working and solve my problems.
For the confirmation look at the listing from "LMTOOLS - Server Status"
Status
Flexible License Manager status on Sat 6/26/2010 00:55
  adskflex: UP v11.7
Feature usage info:
Users of 85552MAPGE_2011_0F:  (Total of 1 license issued;  Total of 1 license in use)
  "85552MAPGE_2011_0F" v1.000, vendor: adskflex
  floating license
    SYSTEM atlas atlas (v1.0) (atlas/27000 101), start Sat 6/26 0:51
DarrenP
welcome
DarrenP
Administrator Productivity
