After what seems a successfull installation, I then run Autocad and it takes about 2 mins. for Windows 7 to configure a whole bunch of stuff. Once this is done, I recieve the following message Lincense Error - Unable to Initiliaze adlm.
Internal Error Message: <Error initliazing the Usage tracking component.> Error Code: <-104>
Then I go ahead to close the message AutoCad stops loading and recieve this other message: FATAL ERROR: Invalid Configuration path\filename: C:\Users\Julio\AppData\Local\Autodesk\AutoCad Map 3D\R19.0\enu\
Here are what I using:
Windows 7 - Home Edition 64bit
Home Use Lincense through my work
If you have any ideas or a solution to this problem, I like to hear from you.
Jr.
Hello
Welcome th the Autodesk/AutoCAD Forums !
Have you alreday installed others Autodesk software on this PC with success ?
If YES, which one ?
Which are remaining on the same PC ?
Win 7 64 bits Home Edition : OK
How much Ram on your PC ?
Bye, Pat
Patrice BRAUD
I'm not sure if that is the reason, but at least I don't find the home-edition of Win7 in the system requirements for Map3D 2013 >>>click<<<.
Have you done that as administrator and with disabled antivirus-software?
Have you already passed the activation of your license?
- alfred -
