Installation & Licensing
Distinguished Contributor
Jroper
Message 1 of 3 (145 Views)
Map upgrade to Infrastructure Design Standard - previous versions?
145 Views, 2 Replies
04-03-2013 09:18 AM
I had a quick question about previous versions and the new offer to upgrade Map to Infrastructure Design Suite Standard.
Will we still have access to previous versions of Map if we are on subscription with this product?  I assume so but just wanted to ask.  We have a client that requires Map 2008.  So we need to set asside a certain amount of licenses for that version.
TravisNave
Message 2 of 3 (144 Views)
Re: Map upgrade to Infrastructure Design Standard - previous versions?
04-03-2013 09:34 AM in reply to: Jroper
Normally, yes.  However, Subscription allows for up to 3 releases back.  Thus if you upgraded to 2014 under Subscription, you could run 2013, 2012, and 2011.  Anything prior is considered retired.  To get an exception for 2008, you would likely have to lose one of your available 2014 licenses to be applied to previous release.  Typically, these are good for 13 months, if approved.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Jroper
Message 3 of 3 (134 Views)
04-03-2013 10:12 AM in reply to: TravisNave
Sounds like we are good then.  We have some normal subscription 2013-2010 (soon to be 2014-2011) licenses and some that are set aside for Map 2008.  Sounds like we can re-request previous versions licenses once they are expired.  Thanks for the quick reply.
