Installation & Licensing
Map 3D 2013 won't start--DLL problem??
1 REPLY 1
6641 Views, 1 Reply
I have AutoCAD 2012, Map 3D 2012, and Map 3D 2013 installed on a PC running Win 7 Enterprise, SP1, 64 bit.
They were installed in the order listed.  The only reason I installed Map 3D 2013 was to use BaseJump.
Map 3D 2013 worked OK for several days, but now, when I open it, I get a Windows System Error that says:
"The program can't start because VCOMP100.DLL is missing from your computer.  Try reinstalling the program to fix this problem."
Has anyone else seen this?  I'm hoping to solve the issue without having to reinstall Map 3D 2013.  I dread installs of AutoCAD, they never seem to go cleanly.
Thank you.
1 REPLY 1
TravisNave
You might need to install or reinstall your MS Visual C++ Redistributable:
http://www.microsoft.com/en-us/download/details.aspx?displaylang=en&id=14632
Autodesk Forums:
Administrator Productivity
