Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
Did you mean:Ā
LT14 Service Pack 1 Error Code 2349 & 1603
3 REPLIES 3
Alasdair1
599 Views, 3 Replies
When I try to install Service Pack 1 to LT14 I get the error code 2349 and Error Code 1603. All help appreciated.
3 REPLIES 3
Alasdair1
in reply to: Alasdair1
I am using Windows 8
TravisNave
Are you experiencing problems with LT that require the SP to be installed?
Autodesk Forums:
Alasdair1
Not having any problems with LT14 so not going to bother to install  its too much hassel not having any problems without SP1 so will leave it thanks for help
Administrator Productivity
