Installation & Licensing
enahuis
245 Views, 5 Replies
LT 2012 LTU
We bought one standalone version of Autocad LT 2012. There are 3 users who need to use the program but don't work on the same time with it.
Can i use the LTU and install this version on 3 pc's and let the users transfer the license between them? It might be possible technically but is it allowed on licenseterms?
5 REPLIES 5
TravisNave
in reply to: enahuis
Yeah, you can attempt this but the LTU is not reliable. Eventually it will break and you will be left without a license.  You might consider upgrading to a full seat of AutoCAD and adding network activation to it.  That way they can all have AutoCAD installed and just share the single network license.  It's worth it.
Autodesk Forums:
pendean
in reply to: TravisNave
It would be cheaper to buy (2) additional LT seats 🙂
TravisNave
in reply to: pendean
Haha!  True indeed.  Smiley Very Happy
Autodesk Forums:
enahuis
Is LTU that buggy? I'll try if it works. When not w start thinking about more licenses
When the export fails i have to reactivate with autodesk?
TravisNave
No, I was exaggerating on the LTU.  It's actually much worse than my description.  And yes, when it fails, you will have to reactivate thru Autodesk.  Good luck!
Autodesk Forums:
Administrator Productivity
