Installation & Licensing
Loading AutoCad LT 2011 twice
3 REPLIES 3
495 Views, 3 Replies
I recently purchased LT 2011 and loaded it on my desktop. I would also like to load it on my laptop. Will AutoCad allow 2 loads from a single seat version?
Thanks.
3 REPLIES 3
TravisNave
Yes. Autodesk allows for a second activation for this purpose. It is in the EULA. It's that long lawyer jargon that you are supposed to read when you click *I AGREE* at the beginning of the installation (that nobody ever actually reads.) It's in there, trust me. 😃
Autodesk Forums:
From the EULA
2.2.1 Standalone (Individual) Version. If Autodesk identifies the Software as a
“Standalone Version” or as an “Individual Version” or if the User Documentation does not
identify the Software by any of the version designations set forth in Sections 2.2.2 through
2.2.6, You may Install and Access one (1) copy of the Software on one (1) individual
Computer, which may not be connected to a network in a manner that allows more than one
(1) user to Access, upload, operate, view or otherwise create or use a copy of the Software.
You may not Install or Access the Software other than on one (1) computer at a time.
TravisNave
Also from the EULA under 3.1 PERMITTED ACTIONS:
3.1.2 Use Away from Usual Work Location.
(a) For Stand-alone (Individual) and Multiseat Stand-alone Versions. If You have acquired a Stand-alone (Individual) Version or Multiseat Stand-alone Versions, for each Permitted Number of copies of the Software, You may Install and Access, solely within Your Territory, one (1) additional copy of the Software on a second Computer provided that:
(i) such second Computer is owned or leased by You (and not by another person, such as Your employee, if any);
(ii) such second Computer is either a portable Computer or a nonserver Computer away from Your usual work location;
(iii) the additional copy of Software is Accessed solely for the purpose of enabling You (or Your employee, if any) to perform work while away from Your usual work location;
(iv) the original and additional copy of the Software are used only by the same person, and only one (1) of the Software copies is Accessed at any one time; and
(v) both copies of the Software are Installed and Accessed exclusively with the copy protection device (if any) supplied with the Software.
Autodesk Forums:
Administrator Productivity
