Installation & Licensing
LMTOOLS - When Performing Status Inquiry, Can't See Full Output
1 REPLY 1
gmehesy
1060 Views, 1 Reply
I've got networked licenses distributed among many servers.  When performing a status inquiry of the licenses, the output stops and I can't see all the servers in our network.  Is there a limitation in LMTOOLS on the number of lines of text that can be shown in status inguiry?
1 REPLY 1
gmehesy
in reply to: gmehesy
Seems to be an issue - here's a workaround...
Recommendation
To view the full active license status list, you can execute the Perform Status Enquiry command via Windows command-prompt, as follows:
  1. Go to Windows Command Prompt
  2. Go to License Manager folder : C:\Program Files\Autodesk Network License Manager
  3. Type command : lmutil.exe lmstat –a
  4. Full activity will be listed in Windows command prompt
For ease in analyzing, you can route the generated content into a text file (eg. output.txt) by using the following command : “> c:\output”
  1. Go to License Manager folder : C:\Program Files\Autodesk Network License Manager
  2. Type : C:\Program Files\Autodesk Network License Manager\lmutil lmstat –a > c:\output.txt.
  3. Output.txt file will be generated with the status content
Administrator Productivity
