Currently we are running LMTOOLS to service network licensing for our 7 3DMAX studio licenses. We have reciently prucheased MAYA 2 network licenses and have our LIC file. We want to set up the MAYA on our current LMTOOLS software so that both 3DMAX and MAYA can issue licenses to workstaitons at the same time. can this be done? or do I need to install a seperate LMTOOLS licensing server?
Adam
You can run both on one license server. In most cases you can simply combine the license files. Are you running 2011 products? Or will you need to use the adskflex and the sgiawd vendors? If you need help with this, I can point you in the right direction.
