I am in the process of installing network licensing for our AutoDesk products
Here are the issues we've run into and the solutions we've tried...
On starting Revit I'm asked to specify the "License Server System", after entering the server name (tried both name and IP Address) I click finish and get the error " Error [-15.570.10035]". I increased the verbosity of the messages i get...
The license server manager(lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: 85862REVIT_2013_0F
Server name: servername
License path: @servername;C:\Program Files\Autodesk\Revit Architecture 2013\Program\licpath.lic
FLEXnet Licensing error:-15,570
See the attached results from the Status Enquiry and Diagnostics. Although the diagnostics shows an issue with "66800REVIT_F", the status enquiry shows it as being available and indicates that the server is up and running fine.
I checked to ensure that..
I've tried the following fixes with no success
This is my first time working with LMTools, but I've about run out of fixes to try.
Any help would be greatly apperciated
Solved by DarrenP. Go to Solution.
you have to unblock port 2080 and ports 27000 to 27009
DarrenP
When you did a PING of wsaimageserver, did you get a valid IPv4 address? Or did it just respond with 0 packet loss on an IPv6 address?
Let me know the results.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
We had unblocked ports 2080 & 27000. We didn't realize 27001-27009 as well. We had to open the ports on the router and on the server for it to work.
Thank You for your help.
