Hi all!
I'm trying to set up LMTools on Windows 2012, which hosts Hyper-V Manager. I have two NICs on it, both of them are used in Hyper-V as virtual switches.
So, LMTools detects wrong Ethernet Address in System Settings tab (it sees only addresses of physical NIC, but they're used in Virtual Hyper-V network, so they have another ethernet addresses).
Thus my client machines can't connect to this server and I get 15.570.0 error.
Any thoughts about how I might solve this problem?
Thanks in advance!
So long as the LIC file matches what LMTOOLS sees, then your license manager should start. If your status shows licenses, then you are golden. If your clients are getting -15 errors, it is either because they cannot connect to ports 27000 or 2080 thru the firewall, or it cannot make the appropriate connection because it is trying IPv6 instead of IPv4.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Yes, when I perform Server Status Inquiry I get this message:"Total of 1 license issued; Total of 0 licenses in use". I tells that my LMTools works fine?
So, the problem is only in firewall/ports?
May it somehow be connected with Hyper-V manager?
Unlikely. NLM works perfectly on VM. So it is likely an IPv6 issue. What do you get when you PING the server from the client?
Also, use Internet Explorer to check the ports:
http://servername:2080
http://servername:27000
You should get a page of jargon if open.
Good Luck!
Yes. When I check this:
I get "page not found" error.
And result for PING:
ping mskdmz
Обмен пакетами с MSKDMZ [::1] с 32 байтами данных:
Ответ от ::1: время<1мс
Статистика Ping для ::1:
Пакетов: отправлено = 4, получено = 4, потеряно = 0
(0% потерь)
Приблизительное время приема-передачи в мс:
Минимальное = 0мсек, Максимальное = 0 мсек, Среднее = 0 мсек
The same picture as in your link http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
But my license server and client for AutoCAD 2014 are not the same computers.
