Installation & Licensing
LMTools Installation on Hyper-V VM Host 2012
5 REPLIES 5
Antoninio
1715 Views, 5 Replies
Hi all!
I'm trying to set up LMTools on Windows 2012, which hosts Hyper-V Manager. I have two NICs on it, both of them are used in Hyper-V as virtual switches.
So, LMTools detects wrong Ethernet Address in System Settings tab (it sees only addresses of physical NIC, but they're used in Virtual Hyper-V network, so they have another ethernet addresses).
Thus my client machines can't connect to this server and I get 15.570.0 error.
Any thoughts about how I might solve this problem?
Thanks in advance!
5 REPLIES 5
TravisNave
in reply to: Antoninio
So long as the LIC file matches what LMTOOLS sees, then your license manager should start.  If your status shows licenses, then you are golden.  If your clients are getting -15 errors, it is either because they cannot connect to ports 27000 or 2080 thru the firewall, or it cannot make the appropriate connection because it is trying IPv6 instead of IPv4.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Autodesk Forums:
Antoninio
in reply to: TravisNave
Yes, when I perform Server Status Inquiry I get this message:"Total of 1 license issued;  Total of 0 licenses in use". I tells that my LMTools works fine?
So, the problem is only in firewall/ports?
May it somehow be connected with Hyper-V manager?
TravisNave
Unlikely.  NLM works perfectly on VM.  So it is likely an IPv6 issue.  What do you get when you PING the server from the client?
Also, use Internet Explorer to check the ports:
http://servername:2080
http://servername:27000
You should get a page of jargon if open.
Good Luck!
Autodesk Forums:
Antoninio
Yes. When I check this:
I get "page not found" error.
And result for PING:
ping mskdmz
Обмен пакетами с MSKDMZ [::1] с 32 байтами данных:
Ответ от ::1: время<1мс
Статистика Ping для ::1:
Пакетов: отправлено = 4, получено = 4, потеряно = 0
(0% потерь)
Приблизительное время приема-передачи в мс:
Минимальное = 0мсек, Максимальное = 0 мсек, Среднее = 0 мсек
The same picture as in your link http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
But my license server and client for AutoCAD 2014 are not the same computers.
TravisNave
Correct. It's still an IPv6 issue. You need to modify your hosts file and
put the correct IPv4 address in for the nlm on each client. Then make sure
the firewall has exceptions on the server for the nlm files.
Autodesk Forums:
Administrator Productivity
