Installation & Licensing
LMTOOLS Does Not See All Licenses In File
5 REPLIES 5
fëanor
532 Views, 5 Replies
Only 1 user at a time is able to use NavisWorks 2014, although we have two licenses.
When I upload our license file at www.licenseparser.com I can see two seats.  Each has its own unique serial number (removed here for privacy):
Package Increments Matched
Seats Feature Feature Code Serial Number Issue Date Expiration
1Subscription Package: Autodesk NavisWorks Manage .167600NAVMAN_F*PastFuture
 Autodesk Navisworks Manage 201486166NAVMAN_2014_0F
 Autodesk Navisworks Manage 201386022NAVMAN_2013_0F
 Autodesk Navisworks Manage 201285839NAVMAN_2012_0F
 Autodesk Navisworks Manage 201185600NAVMAN_2011_0F
However, LMTOOLS does not appear to agree with that analysis.  Even after re-reading the license file and restarting services I still see the same thing
SERVER01: license server UP (MASTER) v11.5
Vendor daemon status (on SERVER01):
adskflex: UP v11.5
Feature usage info:
Users of 67600NAVMAN_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86166NAVMAN_2014_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86022NAVMAN_2013_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85839NAVMAN_2012_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85600NAVMAN_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Where do I go from here?  Thanks in advance for your help!
5 REPLIES 5
DarrenP
in reply to: fëanor
were both licenses generated the same day?
DarrenP
DarrenP
in reply to: DarrenP
the license parser should tell you that
DarrenP
fëanor
Yep they were both generated the same day.  Through what witchcraft/wizardry did you know that?
TravisNave
in reply to: fëanor
I suspect not, since the status enquiry only shows one is available instead of 2.  You might need to get both seats regenerated and combined back into one file.
Autodesk Forums:
fëanor
in reply to: TravisNave
Happy to report that this is resolved.  AutoDesk provided a working license file.  Here is the LMTOOLS output now:
adskflex: UP v11.5
Feature usage info:
Users of 67600NAVMAN_F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 71400NAVMAN_2010_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 86166NAVMAN_2014_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 86022NAVMAN_2013_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 85839NAVMAN_2012_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 85600NAVMAN_2011_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Administrator Productivity
